1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Process PINI-Record again as soon as device is reconnected
From: "Dr. Simon Friederich via Tech-talk" <[email protected]>
Date: Fri, 16 May 2025 16:04:14 +0200
Dear EPICS community,
I have a lot of records that I only need to process once, e.g. to retrieve an identification string or configuration info that I don't need to SCAN periodically.
Normally I just use a field(PINI, "YES") and this information is in the record.
But there are cases, when this procedure fails, e.g. in case the IOC is already running and the device is not "ready" before iocInit. Then these records are invalid and I need to process them manually.
Can you give me a best practice advice on how to deal with this situation?
In most cases I use asyn + streamdevice to talk to my devices so I guess might be some kind of signal comming from asyn "hey, the device is back online, now you can (re)process your PINI-records"?
Thank you very much in advance.
Best regards
Simon
Re: Process PINI-Record again as soon as device is reconnected Ralph Lange via Tech-talk
Prev: Re: camonitor the PACT field Johnson, Andrew N. via Tech-talk
Next: Re: Process PINI-Record again as soon as device is reconnected Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: A $ in a PV name? Johnson, Andrew N. via Tech-talk
