1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Process PINI-Record again as soon as device is reconnected
From: "Friederich, Dr. Simon via Tech-talk" <[email protected]>
Date: Fri, 16 May 2025 18:56:31 +0000
Dear Ralph,
But does @init except handle the case if the ioc is already running before a device is available? I think I've tested both (@init, PINI) and that did not help with this issue.
Best regards
Am 16. Mai 2025, 19:34, um 19:34, Ralph Lange <[email protected]> schrieb:
>On Fri, 16 May 2025 at 16:05, Dr. Simon Friederich via Tech-talk
><[email protected]> wrote:
>In most cases I use asyn + streamdevice to talk to my devices so I
>guess might be some kind of signal comming from asyn "hey, the device
>is back online, now you can (re)process your PINI-records"?
>That's what StreamDevice's @init exception handler does.
>Cheers,
>~Ralph
>https://paulscherrerinstitute.github.io/StreamDevice/protocol.html#except
RE: Process PINI-Record again as soon as device is reconnected Pearson, Matthew via Tech-talk
Process PINI-Record again as soon as device is reconnected Dr. Simon Friederich via Tech-talk
Re: Process PINI-Record again as soon as device is reconnected Ralph Lange via Tech-talk
Prev: Re: Process PINI-Record again as soon as device is reconnected Ralph Lange via Tech-talk
Next: RE: Process PINI-Record again as soon as device is reconnected Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
