1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: [External] Suggestions wanted on IOC hardware
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
To: "James P. Withrow" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 22 May 2025 16:13:09 +0000
Jim,
I’ve got a couple of undergraduate students working to deploy EPICS on Linux at our small lab.  We’ve been doing our testing HP T730 and T740 thin clients because they’re very cheap ($100 on ebay) and so far, have been much faster than we need.   Primarily we’re doing general purpose IO using Keysight (ok, mostly HP and Agilent) 34980A mainframes with multiplexers, ADC outputs, and relay outputs.  We communicate to them using StreamDevice over Ethernet.  We talk to our BRAX vacuum controllers using RS-232, also with StreamDevice.
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
https://orcid.org/0000-0001-7899-5296
From: Tech-talk <[email protected]> On Behalf Of James P. Withrow via Tech-talk
Sent: Wednesday, May 21, 2025 9:03 AM
To: [email protected]
Subject: [External] Suggestions wanted on IOC hardware
Use caution with links and attachments.
Hello all-
I'm investigating the eventual migration of our control system to EPICS, and as such, I would like to solicit community input on IOC hardware which I can use as a 'boilerplate' configuration for common tasks like sensor (I2C/SPI) polling, instrumentation (RS232/485), and general IO.
  • Ideally runs RTEMS and EPICS easily, with Linux and EPICS as a second choice.
  • Supports GPIO and standard peripheral interfaces such as SPI, I2C, and UART.
  • Can be initially set up with a standard configuration but be customized as needed.
  • Has reliable persistent storage for operating system and configuration data.
  • Is slightly more powerful than we think we need at the moment to allow for future-proofing.
Current searching has turned up mostly references to Beaglebone and Zynq hardware, however I'd like to hear from community members as to what's in use 'in the wild' and how well it works - or doesn't - for your applications.
Thanks!
-Jim Withrow
Re: [External] Suggestions wanted on IOC hardware James P. Withrow via Tech-talk
Prev: Strange problem with motor record and MAXv, Movement only possible in one direction Heinz Junkes (FHI) via Tech-talk
Next: Diagnosing and overcoming GigE camera freezes Henrique F. Simoes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: RE: Suggestions wanted on IOC hardware Mark Rivers via Tech-talk
Next: Re: [External] Suggestions wanted on IOC hardware James P. Withrow via Tech-talk
