I took apart cameras from Allied-Vision and FLIR. In both there is very little thermal connection between the internal printed circuit boards and the case.
John Dobbins
From: Tech-talk <[email protected]> on behalf of Henrique F. Simoes via Tech-talk <[email protected]>
Sent: Friday, May 23, 2025 12:21:02 PM To: Engbretson, Mark S. <[email protected]> Cc: Eduardo Pereira Coelho <[email protected]>; [email protected] <[email protected]>; [email protected] <[email protected]> Subject: Re: Diagnosing and overcoming GigE camera freezes Hi, Mark S.
I'm answering inline, and CC'ing tech-talk to have your answer shared and archived as well. On Thursday, May 22, 2025 5:47 PM, Engbretson, Mark S. <[email protected]> wrote: > A lot of GigE camera start blinking their error lights are going offline when > they get even slightly out of their operational range of 50 C Degrees or so. Unfortunately, Basler cameras we use (mostly acA1300-75gm) don't have operational status LEDs. We often see them close to 48°C when they are simply online. We are currently in a shutdown, but there are 40 cameras online in the beamlines right now. 30 of them are below 50°C (mean 48°C, std dev 1°C). The remaining ones are 57 +/- 5 °C. > I know a few that stop working 2 - 3 degrees above that range. Others - people > say (and the stat pv's confirm ) can be run up to 80 C. Interesting. When I started working with these cameras, I saw that it's documented that their temperature can fall into three states: "ok", "critical", and "over temperature" [5]. For the model I mentioned above, it is 72°C to reach critical temperature (only a warning), and 78°C for over temperature, when the camera is expected to stop streaming. From that, I first understood to be fine to work on the 50°C--70°C range. Nowadays, Eduardo Coelho and I aren't convinced that it doesn't affect operation in the long run. > I know that our IT people's first question is "Is its temp outside of the spec > sheet operational range? And if so, have you tried putting a fan of large heat > sink on it." A lot of time , a better passive cooling mount helps. We currently don't use heat sinks. That's something Eduardo has told me before we should consider. Some camera mounts in our photon beam screens don't offer much contact area, which doesn't help with cooling. Some specific ones have a larger metal structure where they are attached. We want to study which cameras freeze more often than others, and check if this turns out to be related to those different cooling aspects. > I.e., people move these things from place to place and ones that worked before > they fail since the ambient cooling is different by a very small amount and > that is enough to run certain models over the edge. Flir ones more than > Basler / Allied Signal . . . Thanks a lot for the input. We'll take small drifts in temperature into account when analyzing our case in more depth. [5] https://nam12.safelinks.protection.outlook.com/?url=""> [6] https://nam12.safelinks.protection.outlook.com/?url=""> -- Henrique F. Simões Control Software Group (SwC) Brazilian Synchrotron Light Laboratory (LNLS) Brazilian Center for Research in Energy and Materials (CNPEM) Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente. Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
