1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Installing .req files via DB vs. REQ?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 23 May 2025 18:01:18 -0500
Hi, Tech-Talkers!
What's the right way for an EPICS module to install .req files?
On RHEL 9 x86_64 with EPICS 7.0.8.1, I've seen some modules that add
.req files to the DB make variable; for example:
  https://urldefense.us/v3/__https://github.com/epics-modules/motor/blob/26efd2f044f6281b5c5889d604cd43f84b4bf615/motorApp/Db/Makefile*L22__;Iw!!G_uCfscf7eWS!Y8ODgDI84V7emUA4orWL6bHzwKq0Si2HpJk-XRcZo2jDfFUZv7grO1CMmT-G8S5WRDyzZ6DWb2APlisRm8b0pg$
And I've seen some modules that add .req files to the REQ make variable;
for example:
  https://urldefense.us/v3/__https://github.com/epics-modules/sscan/blob/6cf674065a7855d4b033b7a97ab941758dac715b/sscanApp/Db/Makefile*L33__;Iw!!G_uCfscf7eWS!Y8ODgDI84V7emUA4orWL6bHzwKq0Si2HpJk-XRcZo2jDfFUZv7grO1CMmT-G8S5WRDyzZ6DWb2APliv3vv5y9g$
For the modules that add .req files to the DB make variable, the .req
files get installed into the module's "db" directory.  And for the
modules that add .req files to the REQ make variable, those .req files
don't seem to get installed anywhere.
So, I'm inclined to think that adding .req files to the DB make variable
is the right way to install .req files, and adding them to the REQ make
variable is wrong and doesn't work.  Or am I missing something?
Thanks!
Lewis
Re: Installing .req files via DB vs. REQ? Johnson, Andrew N. via Tech-talk
Prev: Re: Diagnosing and overcoming GigE camera freezes Henrique F. Simoes via Tech-talk
Next: Re: Diagnosing and overcoming GigE camera freezes Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: EPICS Channel Access UDP Processing Michael Davidsaver via Tech-talk
Next: Re: Installing .req files via DB vs. REQ? Johnson, Andrew N. via Tech-talk
