1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: PVXS programmatically create pvalinks
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Dave Bracey <[email protected]>
Date: Tue, 10 Jun 2025 14:26:25 +0000
> Suppose I programmatically create two PV’s on a server:
> Can I somehow make pv1 INP linked to pv2?
PVXS is just the network protocol layer.
“INP” links are an EPICS database concept.
If you want to use records, and that’s the common thing to do, you create an EPICS database and execute that with `softIocPVX` or a custom IOC setup that includes PVXS. You can now access those records via PVAccess (or also channel access).
In special cases, you might not be able to use records and instead implement some custom code which you then make network-accessible via PVAccess. You can use C++ and PVXS, or python and p4p. In any case, there won’t be “INP” links because there are no records. Ther are also no “SCAN” fields. You need to start your own threads to periodically update the PVs you want to serve. You need to implement whatever you want to happen in your own code.
Start out by trying to use the EPICS IOC.
If you can’t handle the task at hand with plain ai, ao, calc, … records, maybe add some aSub records to call into bespoke C/C++ code.
Writing your own custom PVAccess server should be your last choice.
From: Tech-talk <[email protected]> on behalf of Dave Bracey via Tech-talk <[email protected]>
Date: Tuesday, June 10, 2025 at 10:17
AM
To: Michael Davidsaver <[email protected]>
Cc: [email protected] <[email protected]>
Subject: [EXTERNAL] Re: PVXS programmatically create pvalinks
Thanks Michael – couple questions: Q1: Suppose I programmatically create two PV’s on a server: Value val1 = nt::NTScalar(TypeCode::Int32, true).create(); server::SharedPV pv1 = server::SharedPV::buildMailbox(); string pv1name = "PV1";
Q1:
  pv1.open(val1);
  ioc::server().addPV(pv1name, pv1);
  Value val2 = nt::NTScalar(TypeCode::Int32, true).create();
  server::SharedPV pv2 = server::SharedPV::buildMailbox();
  string pv2name = "PV2";
  pv2.open(val2);
  ioc::server().addPV(pv2name, pv2);
Q(s)2:
I notice if I try to use dbFindRecord on those names, they are not found.  Is this because they have no database records?  Are “Value”, “PV” and “Record” distinct concepts here?  Can a record be attached to them programmatically?
Q(s)3:
Is doing these things programmatically a bad idea here?  In other words, have I reached the extent of what it can do ATM, and I should go back to importing DBD’s?
Thanks –
Dave Bracey, Fermilab
Date: Monday, June 9, 2025 at 9:27
PM
[EXTERNAL] – This message is from an external sender
On 6/5/25 11:13, Dave Bracey via Tech-talk wrote:
I have an application that programmatically creates PV’s using pvxs::ioc::server (based on the examples at https://epics-base.github.io/pvxs/example.html)
Is there any way to create links between these PV’s?
As a note,
I notice that fields that implement timestamp, alarms, display units, etc are implemented in nt.cpp with explicit name strings, and I don’t see anything relevant to links.
nt.cpp is relevant for servers, not PVA links specifically nor PVA clients in general.  PVA link is one specific PVA client which knows how to read/write certain PVA structures to certain types of database record field.
If this is not implemented, I suppose one would build a DB file and call dbLoadRecords on it?  If one does that, can those PV’s reference PV’s created created programmatically?
Speaking of "links" generally refers to the process database feature, which is implemented for database records.  Both CA and PVA links can target local or remote PVs.  This local vs. remote distinction is meant to be mostly abstracted from the prospective of someone writing database files.
https://epics-base.github.io/pvxs/ioc.html#pvaccess-links
Re: PVXS programmatically create pvalinks Dave Bracey via Tech-talk
Re: PVXS programmatically create pvalinks Michael Davidsaver via Tech-talk
Prev: Re: PVXS programmatically create pvalinks Dave Bracey via Tech-talk
Next: Re: PVXS programmatically create pvalinks Dave Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
