1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: PVXS programmatically create pvalinks
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Dave Bracey <[email protected]>
Date: Mon, 9 Jun 2025 19:27:21 -0700
On 6/5/25 11:13, Dave Bracey via Tech-talk wrote:
I have an application that programmatically creates PV’s using pvxs::ioc::server (based on the examples at https://epics-base.github.io/pvxs/example.html)
Is there any way to create links between these PV’s?
As a note,
I notice that fields that implement timestamp, alarms, display units, etc are implemented in nt.cpp with explicit name strings, and I don’t see anything relevant to links.
nt.cpp is relevant for servers, not PVA links specifically nor PVA clients in general.  PVA link is one specific PVA client which knows how to read/write certain PVA structures to certain types of database record field.
If this is not implemented, I suppose one would build a DB file and call dbLoadRecords on it?  If one does that, can those PV’s reference PV’s created created programmatically?
Speaking of "links" generally refers to the process database feature, which is implemented for database records.  Both CA and PVA links can target local or remote PVs.  This local vs. remote distinction is meant to be mostly abstracted from the prospective of someone writing database files.
https://epics-base.github.io/pvxs/ioc.html#pvaccess-links
Re: PVXS programmatically create pvalinks Dave Bracey via Tech-talk
Prev: RE: AreaDetector Driver for device that sends back 3 synchronized frames Mark Rivers via Tech-talk
Next: Re: How to update combo box items with subset of PV items Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: PVXS programmatically create pvalinks Dave Bracey via Tech-talk
Next: Re: PVXS programmatically create pvalinks Dave Bracey via Tech-talk
