1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Retiga E7 and ADKinetix
From: John Dobbins via Tech-talk <[email protected]>
To: "Wlodek, Jakub" <[email protected]>, Mark Rivers <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 13 Jun 2025 13:48:35 +0000
Switching cables and computer USB port has fixed the problem.  Acquisition now continues without stopping randomly.
John
Sent: Friday, June 13, 2025 9:19 AM
To: Wlodek, Jakub <[email protected]>; Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>
I was running the IOC as root.
John
Sent: Friday, June 13, 2025 9:14 AM
To: John Dobbins <[email protected]>; Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>
Hi John,
I don't think this expected. I do not see the behavior on my cameras (though they use PCIE rather than USB). We just purchased some new units, I can try connecting them via USB and let you know if I see the same behavior.
It may be worth trying to remove the udev rule file and try running the IOC as root, just to see if the udev adding/removing is a potential cause for the freeze you are seeing.
Jakub Wlodek
Technology Engineer
Data Acquisition and Detectors
National Synchrotron Light Source II
Office: 631.344.7599
[email protected]
Twitter | Facebook | Instagram | LinkedIn
Sent: Friday, June 13, 2025 9:03 AM
To: Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>; Wlodek, Jakub <[email protected]>
If I run
without any application accessing the camera  I run udevadm monitor
I see that the the camera with remove/unbind  and then  add/bind spontaneously at random intervals.
Is this normal  ??????
John
KERNEL[252737.012467] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-9/2-9:1.0 (usb)
KERNEL[252737.012766] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
KERNEL[252737.012816] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
UDEV  [252737.016445] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-9/2-9:1.0 (usb)
KERNEL[252737.248065] add      /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
KERNEL[252737.249020] add      /devices/pci0000:00/0000:00:14.0/usb2/2-9/2-9:1.0 (usb)
KERNEL[252737.249071] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
UDEV  [252737.249934] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
UDEV  [252737.250662] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
UDEV  [252737.256154] add      /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
UDEV  [252737.257899] add      /devices/pci0000:00/0000:00:14.0/usb2/2-9/2-9:1.0 (usb)
UDEV  [252737.262626] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-9 (usb)
Sent: Thursday, June 12, 2025 12:23 PM
I can start image collection, but it stops after some random number of images,  measured in hundreds.
Says Acquire = Collecting but image counter stuck.
John
Sent: Thursday, June 12, 2025 11:03 AM
To: John Dobbins <[email protected]>; EPICS tech-talk <[email protected]>; Wlodek, Jakub <[email protected]>
Subject: RE: Retiga E7 and ADKinetix
It sounds like the header files or source code are not compatible with the version of the library in the distribution.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Thursday, June 12, 2025 10:03 AM
To: EPICS tech-talk <[email protected]>; Wlodek, Jakub <[email protected]>; John Dobbins <[email protected]>
The same hack also allows the IOC to run.
John
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Thursday, June 12, 2025 10:33 AM
If I do ldd on the EPICS built FanSpeedAndTemperature I see it points to
      libpvcam.so.2 =>  [ ... ]/ADKinetix/lib/linux-x86_64/libpvcam.so.2
I then copy libpvcam.*  from
/opt/pvcam/library/x86_64/
to
[...]/ADKinetix/lib/linux-x86_64
And my EPICS built version of FanSpeedAndControl now works
What is going on?
John
Sent: Thursday, June 12, 2025 10:19 AM
I have the latest ADKinetix source code.
I modified ADKinetix::ADKinetix  to just retrieve the camera name, following
/opt/pvcam/sdk/examples/code_samples
However, the returned name is nonsense. Each run returns a different nonsense result. This was true before my modifications also.
I then did the following:
I verify that I can successfully run
/opt/pvcam/sdk/examples/code_samples/bin/linux-x86_64/release/FanSpeedAndTemperature
Then I copied the example source files
FanSppecandTemperature.cpp
Common.cpp
Common.h
version.h
to
ADKinetix/kinetixApp/src
And I add these lines to the Makefile
PROD_HOST += FanSpeedAndTemperature
FanSpeedAndTemperature_LIBS += pvcam
FanSpeedAndTemperature_SRCS += FanSpeedAndTemperature.cpp
FanSpeedAndTemperature_SRCS += Common.cpp
Which builds FanSpeedAndTemperature  using the EPICS build system
The version of FanSpeedAndTemeprature built in this way has the same behavior, outputs a random nonsense name
PVCAM initialized
Number of cameras found: 1
Camera 0 name: '��b"�'
I don't know how to proceed. Any advice appreciated.
John
Sent: Tuesday, June 10, 2025 12:31 PM
[email protected]>
Subject: Retiga E7 and ADKinetix
I have a new  Teledyne Retiga E7.
I first tested on windows using the PVCAM software and the Beacon software.
Next on Linux, Alma 9,  I verified that /opt/pvcam/bin/PVCamTest/x86_64/'PVCanTestCli   succeeds.
Then using ADKinetix R1-1,  base-7.0.6 , areaDetector-R3-13  I get a segfault  (see below)
What should I do next?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
[root@lnx591 iocKinetix]# ../../bin/linux-x86_64/kinetixApp st.cmd
#!../../bin/linux-x86_64/kinetixApp
< /epics/common/xf31id1-lab3-ioc1-netsetup.cmd
Can't open /epics/common/xf31id1-lab3-ioc1-netsetup.cmd: No such file or directory
errlogInit(20000)
< envPaths
epicsEnvSet("IOC","iocKinetix")
epicsEnvSet("TOP","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADKinetix/iocs/kinetixIOC")
epicsEnvSet("ADKINETIX","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADKinetix/iocs/kinetixIOC/../..")
epicsEnvSet("SUPPORT","/nfs/chess/epics/det/support_alma")
epicsEnvSet("ASYN","/nfs/chess/epics/det/support_alma/asyn-R4-45")
epicsEnvSet("AREA_DETECTOR","/nfs/chess/epics/det/support_alma/areaDetector-R3-13")
epicsEnvSet("ADSUPPORT","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADSupport")
epicsEnvSet("ADCORE","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADCore")
epicsEnvSet("AUTOSAVE","/nfs/chess/epics/det/support_alma/autosave-R5-11")
epicsEnvSet("BUSY","/nfs/chess/epics/det/support_alma/busy-R1-7-4")
epicsEnvSet("CALC","/nfs/chess/epics/det/support_alma/calc-R3-7-5")
epicsEnvSet("SNCSEQ","/nfs/chess/epics/det/support_alma/seq-R2-2-9")
epicsEnvSet("SSCAN","/nfs/chess/epics/det/support_alma/sscan-R2-11-5")
epicsEnvSet("DEVIOCSTATS","/nfs/chess/epics/det/support_alma/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/nfs/chess/epics/det/base-7.0.6")
dbLoadDatabase("/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADKinetix/iocs/kinetixIOC/dbd/kinetixApp.dbd")
kinetixApp_registerRecordDeviceDriver(pdbbase)
# Prefix for all records
epicsEnvSet("PREFIX", "RE7")
# The port name for the detector
epicsEnvSet("PORT",   "KTX")
# The queue size for all plugins
epicsEnvSet("QSIZE",  "20")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADCore/db")
ADKinetixConfig(0, "KTX")
Segmentation fault (core dumped)
Re: Retiga E7 and ADKinetix Wlodek, Jakub via Tech-talk
Retiga E7 and ADKinetix John Dobbins via Tech-talk
Re: Retiga E7 and ADKinetix John Dobbins via Tech-talk
RE: Retiga E7 and ADKinetix Mark Rivers via Tech-talk
Prev: Re: Retiga E7 and ADKinetix John Dobbins via Tech-talk
Next: Re: Retiga E7 and ADKinetix Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
