1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Question about getting hexadecimal data with StreamDevice
To: [email protected]
Date: Thu, 19 Jun 2025 19:44:26 +0800 (CST)
Hello, everyone:
I have a current-readout  device,  communicate with RS232, baud rate 115200, 8 bits data, 1 bit stop, no parity.
When send "\x5A\xA5\x55\x00", it should return data as "5A A5 XX YY ZZ ZZ",  such as"\x5a\xa5\x03\x06\x7f\xe8", and we can get current data from "ZZ ZZ".
The Device provids these simple information above. With a serial port assistent on Windows, we can get all the data correctly.
For example, send "5A A5 55 00" as hexadecimal data, get "5a a5 03 06 7f 07", also as hexadecimal data.
Now I use EPICS StreamDevice to connect the device, communication is correct, I want to save return dada to a record A and another record B. But I can not get right return data.
Here attached the details. Does anyone know why? What's the problem here? How can I get all the returned data "ZZ ZZ" to two PVs such as A and B?
Hope for your advice, thank you very much.
1. Use the ai record (A,B,C,D) to receive returned data, with record and proto file  like this:
record(ai, "data")
     field(DTYP, "stream")
     field(INP, "@wcm.proto  readdata  wcm")
     field(SCAN, "1 second")
wcm.proto:
OutTerminator=CR LF;
InTerminator=CR LF;
readdata{
    out "\x5A\xA5\x55\x00";      #it shows wrong if ther is a space " " between 5A and A5.
    in "\x5A\xA5\x03\x06%(A)2x%(B)2x"
I think I should get A=7f, B=07.
But, the executing result:
Then I try to use string type to get all the turned back data, it seems I can not do that.
2. Use string record (A, B,C,D)to receive returned data:
record(stringin, "data")
wcm.proto:
InTerminator=CR LF;
readdata{
    in "\x5A\xA5%(A)28c"
 Executing result:
   3. Use string record (A, B,C,D)to receive returned data:
wcm.proto:
InTerminator=CR LF;
readdata{
    in "%s"
 Executing result (The same as last one):
Look forward to your advice. Thank you again.
Best wishes,
Kevin
6/19/2025
Re: Question about getting hexadecimal data with StreamDevice Mark Rivers via Tech-talk
Prev: Installing EPICS on Windows Abdalla Ahmad via Tech-talk
Next: RE: Failed to integrate Archiver Appliance with Phoebus Sky Brewer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: Question about getting hexadecimal data with StreamDevice Mark Rivers via Tech-talk
