Hi Mark!
I suppose the problem is in product's ID.
Newport-CONEX-AGP's "idProduct=3006" *is* listed among supported IDs in
ftdi_sio_ids.h, see https://urldefense.us/v3/__https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/usb/serial/ftdi_sio_ids.h?h=v6.16-rc2__;!!G_uCfscf7eWS!cEIzCUjhW53L-KKEAV3e3SDEZCubl_LXE7ev4lxhWZfS5l5_fb1Uvx73nAo1Qmei1z1rHE3YjXYUZg_-sksd1QU4UU-cxedRxvU$
#define NEWPORT_CONEX_AGP_PID 0x3006
(and in ftdi_sio.c driver too)
while CONEX-AGAP's "idProduct=3008" is not, even in the latest kernel
version 6.16 (AFAIR, RHEL9 uses Linux kernet 5.14).
With best regards,
Dmitry
On Fri, 20 Jun 2025, Mark Rivers via Tech-talk wrote:
Folks,
I have an older Newport-CONEX-AGP controller that works fine on Linux.
https://urldefense.us/v3/__https://www.newport.com/f/agilis-piezo-linear-stage-with-conex-controller__;!!G_uCfscf7eWS!esBpnKdccckn_TlnsWE5ruJncpjWNfxHfi8SNZ2M5qWp8ab4wjlgsB18EO_4YOzuwREd1qW6ipequMg2cHFGxsaFyd4$
The device has a USB interface and uses FTDI. When I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62289.315988] usb 1-4: new full-speed USB device number 10 using xhci_hcd
[62289.447505] usb 1-4: New USB device found, idVendor=104d, idProduct=3006, bcdDevice= 6.00
[62289.447514] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62289.447518] usb 1-4: Product: CONEX-AGP
[62289.447520] usb 1-4: Manufacturer: Newport
[62289.447522] usb 1-4: SerialNumber: A6UJN7YS
[62289.450490] ftdi_sio 1-4:1.0: FTDI USB Serial Device converter detected
[62289.450536] usb 1-4: Detected FT232R
[62289.451085] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB0
The device is now available on /dev/ttyUSB0.
I expected to be able to do the same thing with a newer CONEX-AGAP controller.
https://urldefense.us/v3/__https://www.newport.com/f/conex-piezo-absolute-positioning-mirror-mount__;!!G_uCfscf7eWS!esBpnKdccckn_TlnsWE5ruJncpjWNfxHfi8SNZ2M5qWp8ab4wjlgsB18EO_4YOzuwREd1qW6ipequMg2cHFG2VO-mdQ$
However, when I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62360.327898] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[62360.327934] ftdi_sio 1-4:1.0: device disconnected
[62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
[62363.655966] usb 1-4: New USB device found, idVendor=104d, idProduct=3008, bcdDevice= 6.00
[62363.655975] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62363.655978] usb 1-4: Product: CONEX-AGAP
[62363.655980] usb 1-4: Manufacturer: Newport
[62363.655982] usb 1-4: SerialNumber: A694ND5H
Note that I do not get the messages about ftdi_sio detected or the message about attaching to ttyUSBx.
The new CONEX-AGAP works fine on Windows, where it appears as a COM port. I can configure the COM port with EPICS:
drvAsynSerialPortConfigure("serial1", "COM5", 0, 0, 0)
asynOctetSetInputEos("serial1",0,"\r\n")
asynOctetSetOutputEos("serial1",0,"\r\n")
asynSetOption("serial1",0,"baud","921600")
asynSetOption("serial1",0,"bits","8")
asynSetOption("serial1",0,"stop","1")
asynSetOption("serial1",0,"parity","none")
asynSetOption("serial1",0,"clocal","Y")
asynSetOption("serial1",0,"crtscts","N")
Given the behavior on Windows, I think the CONEX-AGAP is also an FTDI device. But if so, then why is Linux not recognizing it as such?
_________________________________________
Dmitry Yu. Bolkhovityanov
The Budker Institute of Nuclear Physics
Novosibirsk, Russia
- Problem with Newport CONEX-AGAP FTDI device on Linux Mark Rivers via Tech-talk
Re: Problem with Newport CONEX-AGAP FTDI device on Linux James P. Withrow via Tech-talk
RE: Problem with Newport CONEX-AGAP FTDI device on Linux Mark Rivers via Tech-talk
<2025>
2026
EPICS Clients in C++ Abdalla Ahmad via Tech-talk
<2025>
2026
