1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Some questions about CaLab
From: Dariush Hampai via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Fri, 20 Jun 2025 17:27:15 +0200
Hi all,
I have some problems with CaLab, necessary to integrate epics with a LabView interface. In particular now I have two big problems: 1) i don't understand how to use multiple field in the same CA. For example, my newport IOC includes some records of the type
mm4006:m11.HOMF
mm4006:m11.MOVN
etc...
CaLab Put.vi does not include the field. What do I do? if I put (for example) mm4006:m11.HOMF and mm4006:m11.MOVN as PV I find two distinct PVs... 2) I am trying to generate a monitor of the various IOCs. When starting LabView there is no PV (via CaLab info.vi). If I start the IOCs I see the PVs. However if I stop the IOCs, via command prompt (caget etc...) I do not see (obviously) the active CA, while via CaLab info.vi the CA are still active and give me the last values read. Even after a reset of PV, using CaLab_Disconnect.vi, I still see the active CAs with the last value read. Where am I going wrong?
Dariush
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room:	+39.06.9403.5248
Lab.:	+39.06.9403.2286
Mob.:	+39.06.9403.8025
Fax.:	+39.06.9403.2597
Prev: Re: EPICS support for device to monitor Digital I/O Mark Rivers via Tech-talk
Next: Problem with Newport CONEX-AGAP FTDI device on Linux Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Next: Re: [EXTERNAL] Some questions about CaLab Dariush Hampai via Tech-talk
ANJ, 20 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
