Hi Dariush,
I know I'm not Carsten, but I've used his software in LabVIEW. I'm not sure I understand what you are trying to achieve, so apologies if I over explain things, I'd rather ensure the fundamentals are clear in our minds so that we can communicate clearly.
As regards the array version of the VI, it is a different VI to the single one and is using an overloading pattern which means it looks the same, but isn't, whether you send it an array or a direct item. So the act of sending it an array is the same effect
as doing one then then other.
The LabVIEW architecture will not be having any influence here as the programs are talking via channel access, which is one of the EPICS protocols, neither program knows about the other, they just have these tokens on a channel and they use those to do other
things with them.
The above means that the IOC needs to be running to see anything. So for an array, the code to send it would actually make it two sends. using the example that Carsten gave it would send:
caput mm4006:m11.HOME 12
caput mm4006:m11.MOVN 24
I'm struggling to understand what you are trying to do with the second part, what is the workflow you have? From a quick look at the VI CaLab Info caches the data, as it isn't data to retrieve regularly in most use cases. Knowing what you are trying to achieve,
not just the problem, will help people provide good information and answers.
Kathryn
I have Long Covid, and work an adapted pattern to allow me to give my best to work, please respond to any emails as fits your own working patterns, and I will respond within my own as soon as I am able.
I am Autistic, and this can impact my communication with others, please be patient with me.
Hi Carsten,
this means that if I send a CaLab get.vi with PV mm4006:m11 and the array field [HOMF,MOVN] I receive an array of value [12,24]... is it right?
The second question is more important... in someway even using disconnect all PV (or sending directly the names of PV to disconnect), with CaLab Info.vi I have in back all the PVs.
Is it possible that the problem is with the architecture of Labview? i.e., Labview64 or Labview32?
Awaiting your replay
Dariush
Il 23/06/2025 07:31, Carsten Winkler ha scritto:
The CA Lab does not have a function for writing multiple fields in a single channel access command.
Fields are written by adding the field name with a dot.
If you need to write to multiple fields, you can use array parameters as follows:
Carsten
Send Tech-talk mailing list submissions to
[email protected]
To subscribe or unsubscribe via the World Wide Web, visit
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
[email protected]
You can reach the person managing the list at
[email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
1. Re: Problem with Newport CONEX-AGAP FTDI device on Linux
(James P. Withrow)
2. Re: Problem with Newport CONEX-AGAP FTDI device on Linux
(Dmitry Yu. Bolkhovityanov)
3. Some questions about CaLab (Dariush Hampai)
4. RE: Problem with Newport CONEX-AGAP FTDI device on Linux
(Mark Rivers)
Message: 1
<snip - irrelevant to conversation?
Message: 2
<snip - irrelevant to conversation>
Message: 3
Date: Fri, 20 Jun 2025 17:27:15 +0200
To: [email protected]
Subject: Some questions about CaLab
Message-ID: [email protected]" id="OWAdca828a4-2ac5-d200-2552-6451f0bc02fe" class="x_moz-txt-link-rfc2396E OWAAutoLink">< [email protected]>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi all,
I have some problems with CaLab, necessary to integrate epics with a
LabView interface. In particular now I have two big problems:
1) i don't understand how to use multiple field in the same CA. For
example, my newport IOC includes some records of the type
mm4006:m11.HOMF
mm4006:m11.MOVN
etc...
CaLab Put.vi does not include the field. What do I do? if I put (for
example) mm4006:m11.HOMF and mm4006:m11.MOVN as PV I find two distinct
PVs...
2) I am trying to generate a monitor of the various IOCs. When starting
LabView there is no PV (via CaLab info.vi). If I start the IOCs I see
the PVs. However if I stop the IOCs, via command prompt (caget etc...) I
do not see (obviously) the active CA, while via CaLab info.vi the CA are
still active and give me the last values read. Even after a reset of PV,
using CaLab_Disconnect.vi, I still see the active CAs with the last
value read. Where am I going wrong?
Dariush
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room: +39.06.9403.5248
Lab.: +39.06.9403.2286
Mob.: +39.06.9403.8025
Fax.: +39.06.9403.2597
