1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: areaDetector/asynPortDriver order of parameter initialization
To: Irie Railton - STFC UKRI <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 23 Jun 2025 15:47:23 +0000
Hi Irie,
  • On initialisation my asyn parameters are being processed, and then I have a thread that handles the changes and passes them on to the camera. For some of my parameters, processing a change involves getting the value of another parameter but for a couple of them this other parameter is not yet initialized so it is giving me an asynParamUndefined status.
  • So I had a look into ADCore and I can't figure out what causes the parameters to process on startup, and why the order of initialization is the way it is.
  • So my question is: how is the order of parameter initialisation decided and can it be modified?
I think by “parameters to process on startup” you probably mean that your writeInt32(), writeFloat64() and writeOctet() methods are being called with those parameters, correct?  Those functions are called at iocInit because the output records have PINI=YES and so they process once at iocInit.
That is order is set in EPICS base which I believe does the initialization for each record type in order.  The order in which your functions are called can be changed using the PHAS field of the record.
There are several ways to handle this in your code.
  1. You can do nothing if any of the records have not yet processed (getting other parameter value returns asynParamUndefined).  By the end of iocInit all records will have processed, so the last one to process will result in your code writing to the hardware.
  2. You can initialize all of the parameters in your constructor (setIntegerParam(), setDoubleParam(), etc.) with “reasonable” values.  Then you won’t get asynParamUndefined.  As iocInit proceeds the values read will contain the actual values from the database or from autosave.
Let me know if this does not answer your question.
From: Tech-talk <[email protected]> On Behalf Of Irie Railton - STFC UKRI via Tech-talk
Sent: Monday, June 23, 2025 10:16 AM
To: [email protected]
Subject: areaDetector/asynPortDriver order of parameter initialization
Hello EPICS community,
I'm working on an areaDetector driver for PIXCI frame grabbers and associated cameras (ADPixci), and I'm having an issue with accessing uninitialized parameters.
Kind regards,
Irie Railton
Software Engineer
Software Controls Group
CLF Engineering Division
areaDetector/asynPortDriver order of parameter initialization Irie Railton - STFC UKRI via Tech-talk
Prev: Re: Some questions about CaLab (Dariush Hampai) Dariush Hampai via Tech-talk
Next: Re: Some questions about CaLab (Dariush Hampai) Kathryn Baker - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: areaDetector/asynPortDriver order of parameter initialization Irie Railton - STFC UKRI via Tech-talk
Next: Issues in MCA module with XFlash detector Abdalla Ahmad via Tech-talk
