Subject: |
Re: Some questions about CaLab (Dariush Hampai) |
Dariush Hampai via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 23 Jun 2025 17:18:06 +0200 |
Hi Kathryn,
thank you for your answer. Yoyu're right (Labview on windows).
However I don't see any process in Task Manager that can store all
the PV informations.
In order to explain better, i Started the SoftDemo.vi, so all the
PV presented are stored.
I stopped it and closed it.
Then I create a very simple VI (in attachment the front panel and
the block diagram) in order to explain better which is my problem.
As you can see, I tried to disconnect in two ways the PVs (by name
and all togheter). However the PVs remain stored.
Dariush
Il 23/06/2025 16:52, Kathryn Baker -
STFC UKRI via Tech-talk ha scritto:
Hi
Dariush,
I may have been wrong with the caching aspect, but as I say a
quick look at the LabVIEW code for CaLab Info has a case
structure and feedback nodes which I'd say are in keeping with
a functional global variable (this is a LabVIEW VI of a specific
type, the VI doesn't follow that style properly, but I'd say
does much the same thing.) So what I think it is doing is asking
for the information the first time it is called, and then
keeping that information in memory and returning it - depending
on how you are calling it. (Would need to the LabVIEW code to do
more than make this as a random stab in the dark guess.) This is
supposition based on minimal information. But that might only be
the case if the IOC is actually stopped, otherwise, if the IOC
is running the PVs will be there, you can't stop or disconnect a
PV at the IOC side easily from the LabVIEW side.
(For the experts, yes, I'm aware of the DIS fields, but I'm not
certain the use case here is involving them, and they may be an
additional complexity that isn't needed.)
CaLab is certainly the option I've found best when integrating
on the LabVIEW side, but you do need a reasonable
understanding of what each side is expecting and how they
behave to be able to get the best results.
Please note, I have assumed that LabVIEW is running on a
Windows system rather than the Linux system, which is again
something that would make a difference to how things might be
interacting.
So starting CaLabSoftIOC.vi will spawn the IOC as a separate
process, that process knows nothing about LabVIEW, it will
just run on the same computer that LabVIEW was running on all
on it's own. Check out the task manager, you will see it in
the list. So simply stopping LabVIEW won't stop the IOC. I'm
intrigued that it survived a restart of the computer though.
However, it would restart as soon as you start the VI, so it
might be worth trying that again and checking in task manager
before starting the IOC.
Regarding the architecture, you need to run the version that
matches the OS you are on, as there are DLLs underneath which
care about that.
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room: +39.06.9403.5248
Lab.: +39.06.9403.2286
Mob.: +39.06.9403.8025
Fax.: +39.06.9403.2597
- Re: Some questions about CaLab (Dariush Hampai) Kathryn Baker - STFC UKRI via Tech-talk
- Re: Some questions about CaLab (Dariush Hampai) Carsten Winkler via Tech-talk
- Re: Some questions about CaLab (Dariush Hampai) Dariush Hampai via Tech-talk
areaDetector/asynPortDriver order of parameter initialization Irie Railton - STFC UKRI via Tech-talk
RE: areaDetector/asynPortDriver order of parameter initialization Mark Rivers via Tech-talk
<2025>
2026
<2025>
2026
