1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: [EXTERNAL] Re: Suggestions wanted on IOC hardware
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
To: Steven Hunt <[email protected]>, "Hill, Jeff" <[email protected]>
Date: Tue, 24 Jun 2025 18:53:13 +0000
Is there any hardware available that supports this approach?  The only things that I’m aware of are VME-based high-speed, high-resolution digitizers.  These don’t seem suitable for data as slow as 10Hz.  Currently our fastest controls data is only being gathered at 1Hz, and our standard interval is 1 or 2 samples per minute.
Our neutron and gamma ray detectors often utilize VME or dedicated ADC hardware, but they also use custom software for near real-time visualization.  I don’t know that EPICS would make sense there, as I feel that it requires substantial background knowledge and effort to implement.
    Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
https://orcid.org/0000-0001-7899-5296
From: Tech-talk <[email protected]> On Behalf Of Steven Hunt via Tech-talk
Sent: Tuesday, June 3, 2025 12:33 PM
To: Hill, Jeff <[email protected]>
Cc: [email protected]
Subject: Re: [EXTERNAL] Re: Suggestions wanted on IOC hardware
I was trying to be neutral, but if I was building a new system today, especially if timing and longevity  was important   ..... I would still go with the 'old fashioned'  flat architecture, and open backplane for all signals, fast and slow.
Remember, people (effort) costs more than hardware
But that is me.
On Tue, Jun 3, 2025 at 9:17 AM Hill, Jeff <[email protected]> wrote:
From: Tech-talk <[email protected]> on behalf of Steven Hunt via Tech-talk <[email protected]>
Sent: Friday, May 30, 2025 12:21 PM
To: James P. Withrow <[email protected]>
Cc: [email protected] <[email protected]>
Subject: [EXTERNAL] Re: Suggestions wanted on IOC hardware
>> 'old fashioned' systems using VME
For slow controls,  vendor agnostic back-plane modular systems such as VME are certainly more expensive, but for DSP based timed data acquisition a  modern equivalent system such as VPX may still  remain to be relevant!
If the system should be installed over a long time period then vendor neutrality and modular components become bigger considerations, but yes for slow controls Ethernet can be our vendor neutral modular integration interface.
>> except we seem to be moving back to this old model, IOCs no longer have direct hardware interface, but run on unix systems and talk to the low level I/O systems which can be PLCs, simple embedded systems not running EPICS, or instruments.
Yes, for slow controls, but for timed scalar, waveform, and image data  acquisition perhaps the the low latency flat model remains valid.
Control room operators conntinue to identify the flat model as being miuch simpler to fault isolate. They like to identify what IOC the EPICS PV is on and restart it. Yes, they shouldnt need to do that, but in the middle of the night its expedient.
>> OK, I sound like a grumpy old man (may be old but not grumpy) .
Get in line!
On Wed, May 21, 2025 at 6:02 AM James P. Withrow via Tech-talk <[email protected]> wrote:
Hello all-
I'm investigating the eventual migration of our control system to EPICS, and as such, I would like to solicit community input on IOC hardware which I can use as a 'boilerplate' configuration for common tasks like sensor (I2C/SPI) polling, instrumentation (RS232/485), and general IO.
  • Ideally runs RTEMS and EPICS easily, with Linux and EPICS as a second choice.
  • Supports GPIO and standard peripheral interfaces such as SPI, I2C, and UART.
  • Can be initially set up with a standard configuration but be customized as needed.
  • Has reliable persistent storage for operating system and configuration data.
  • Is slightly more powerful than we think we need at the moment to allow for future-proofing.
Current searching has turned up mostly references to Beaglebone and Zynq hardware, however I'd like to hear from community members as to what's in use 'in the wild' and how well it works - or doesn't - for your applications.
Thanks!
-Jim Withrow
Re: [EXTERNAL] Suggestions wanted on IOC hardware Heinz Junkes via Tech-talk
Suggestions wanted on IOC hardware James P. Withrow via Tech-talk
Re: Suggestions wanted on IOC hardware Steven Hunt via Tech-talk
Re: [EXTERNAL] Re: Suggestions wanted on IOC hardware Hill, Jeff via Tech-talk
Re: [EXTERNAL] Re: Suggestions wanted on IOC hardware Steven Hunt via Tech-talk
Prev: SNS Controls Integration Group Leader Position White, Karen S. via Tech-talk
Next: Re: EPICS Clients in C++ Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: [EXTERNAL] Re: Suggestions wanted on IOC hardware Steven Hunt via Tech-talk
Next: Re: [EXTERNAL] Suggestions wanted on IOC hardware Heinz Junkes via Tech-talk
