Actually, the CA client library implementation in Base is written in C++, but it was designed to provide the exact same C API as the original C-based version. It was also written long before modern C++ standards,
and was designed for targets where real-time code was required to minimize how often it allocated and released memory to avoid fragmentation.
If someone were so inclined it should be possible to create a new C++ API for it that calls the private implementation, but there might be some impedance mismatches when doing that because of the way the code
does memory allocation and uses containers.
The libCa code was written by Jeff Hill who retired from the Los Alamos National Lab quite a few years ago now, and the current Core Developers don’t often make changes to the implementation. It is very stable
code that does what it was designed for well, but the community went in a different direction when we chose to use PV Access as a new network protocol. Some labs are likely to continue using CA for many years so we won’t be throwing it out, but new projects
are being steered towards PVA since it can support IPv6 and secure communications. Those could be retro-fitted onto CA, but we have chosen to spend the effort on the newer protocol.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Hi Laurenz and Abdalla,
I too have some experience with CAFE from PSI. It is quite good in my opinion once you get the CAFE working (not difficult). On the other hand, I am not sure if CAFE is what Abdalla is after; he is looking for C++ library, not
a wrapper. At least when I looked at CAFE the last, it was more of a wrapper than a true C++ library (except that I have not used it for several years that it might have changed).
In fact, I thought about replying to Abdalla with CAFE, until I read his original e-mail very carefully.
Best,
Jiro
On 06/24/2025 9:28 AM, Laurenz Rettig via Tech-talk wrote:
-------- Ursprüngliche Nachricht --------
Datum: 24.06.25 08:42 (GMT+02:00)
Betreff: RE: EPICS Clients in C++
Thanks Ralph. Is there something similar for channel access? In other words, a C++ implementation of channel access?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
Email :
[email protected]
Website: www.sesame.org.jo
Is there a client API for EPICS implemented in C++ not just a wrapper for the C API? Possibly using recent C++ standards?
- RE: EPICS Clients in C++ Laurenz Rettig via Tech-talk
- Re: EPICS Clients in C++ Fujita Jiro via Tech-talk
RE: [EXTERNAL] Re: Suggestions wanted on IOC hardware Leblanc, Gregory via Tech-talk
Re: Diagnosing and overcoming GigE camera freezes Daykin, Evan via Tech-talk
<2025>
2026
RE: EPICS Clients in C++ [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
