Hi Simon,
Thanks for reaching out and the suggestion – I gave both ChatGPT and CoPilot a try, but it looks like many of the sequence files I tried breached the character limits of the tool (sequence contains (48k characters)!
Clearly I need to be making smaller sequences, haha.
But still an interesting idea – I’ll keep hunting around for other LLM/systems that might have larger character limits as this could still prove interesting.
Ed Janke
[You don't often get email from [email protected]. Learn why this is important at
https://aka.ms/LearnAboutSenderIdentification ]
Dear Ed
An alternative, low-effort, approach that might work as a “quick
look” at the states in your SNL file, is to ask ChatGPT to
generate a PlantUML (or perhaps Mermaid) diagram for you.
Just for fun I asked the GPT-4o model to visualize the states
in the homing procedure that initializes one of our
stepper-motor controlled range-shifter devices.
It seems to have made a reasonable job of it (see attached
screenshot), though not as detailed as the diagram I made
years ago, laboriously, using a UML modelling tool.
Just throwing the idea out there, although most of you are
probably already aware of it…
Best regards
Simon Rees
On 27.06.2025 02:55, Ed Janke via Tech-talk wrote:
> Hello!
> Does anyone know if there is software out there that can parse the SNL
> in an EPICS Sequence file to generate a state diagram for every state set?
> I was considering doing this by hand but figured I would ask the greater
> community in case this already exists.
> Thanks,
> Ed Janke
- Generation of state diagram documentation from SNL Ed Janke via Tech-talk
- Re: Generation of state diagram documentation from SNL Rees Simon via Tech-talk
- Re: Generation of state diagram documentation from SNL Ed Janke via Tech-talk
Recall: Re: Generation of state diagram documentation from SNL Ed Janke via Tech-talk
EPICS support for CAEN V2740 / V2745 digitizers? Diego Omitto via Tech-talk
<2025>
2026
Re: Generation of state diagram documentation from SNL Hao, Hao via Tech-talk
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
