1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: help requested about motorPI module
From: Dariush Hampai via Tech-talk <[email protected]>
To: "Peterson, Kevin M." <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 14 Jul 2025 16:55:31 +0200
Hi Kevin
following your suggestions I modify the PI_C663.cmd as following:
#drvAsynSerialPortConfigure("serial1", "/dev/ttyS0", 0, 0, 0)
dbLoadTemplate("PI_C663.substitutions")
# PI C-663 driver setup parameters:
#     (1) maximum number of controllers in system
#     (2) motor task polling rate (min=1Hz,max=60Hz)
PIC663Setup(2, 10)
# PI C-663 driver configuration parameters:
#     (1) controller# being configured
#     (2) ASYN port name
#     (3) address (GPIB only)
PIC663Config(0, "serial_pi_1")
#!drvPIC844debug = 4
1) However, is it right "PIC663Config(0, "serial_pi_1")", or "0 controller# being configured?
PI_C663.substitutions as
file "$(MOTOR)/db/motor.db"
pattern
{P,     N,  M,        DTYP,      C,  S,  DESC,          EGU, DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC, DHLM,  DLLM,  INIT} {pi_1:,   1,  "m$(N)",  "PIC663",  0,  0,  "L-611.90 $(N)", degrees,  Pos,  25,     .1,    200,    0,     1,     .2, 102400,  4,     1000000,   -100,  ""} {pi_1:,   2,  "m$(N)",  "PIC663",  0,  0,  "PLS-85 $(N)",  mm, Pos,  10,     .2,    200,    0,     1,     .2,    409600,  3, 102,   -1,  ""}
2) running the st.cmd I obtain errors on controller cards:
[xlabsrv2@xlabsrv2 iocPI]$ ./st.cmd
#!../../bin/linux-x86_64/pi
## You may have to change pi to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","iocPI")
epicsEnvSet("TOP","/home/xlabsrv2/epics/IOCs/piIOC")
epicsEnvSet("SUPPORT","/home/xlabsrv2/epics/synApps_6_3/support/")
epicsEnvSet("ASYN","/home/xlabsrv2/epics/synApps_6_3/support//asyn-R4-44-2")
epicsEnvSet("STREAM","/home/xlabsrv2/epics/synApps_6_3/support//StreamDevice-2-8-24")
epicsEnvSet("MOTOR","/home/xlabsrv2/epics/synApps_6_3/support/motor-R7-3-1")
epicsEnvSet("EPICS_BASE","/home/xlabsrv2/epics")
epicsEnvSet("SNCSEQ","/home/xlabsrv2/epics/synApps_6_3/support//sequencer-mirror-R2-2-9")
epicsEnvSet("BUSY","/home/xlabsrv2/epics/synApps_6_3/support//busy-R1-7-4")
epicsEnvSet("IPAC","/home/xlabsrv2/epics/synApps_6_3/support//ipac-2-16")
epicsEnvSet("LUA","/home/xlabsrv2/epics/synApps_6_3/support//lua-R3-1")
######cd "${TOP}"
dbLoadDatabase "../../dbd/pi.dbd"
pi_registerRecordDeviceDriver pdbbase
#####cd "${TOP}/iocBoot/${IOC}"
## motorUtil (allstop & alldone)
dbLoadRecords("/home/xlabsrv2/epics/synApps_6_3/support/motor-R7-3-1/db/motorUtil.db", "P=pi_1:")
drvAsynIPPortConfigure("serial_pi_1","100.100.0.11:4001",0,0,0)
asynOctetSetInputEos("serial_pi_1",0,"\n")
asynOctetSetOutputEos("serial_pi_1",0,"\n")
< PI_C663.cmd
PIC663Setup(2, 10)
#!< PI_C844.cmd
#!< PI_C848.cmd
#!< PI_E662.cmd
#!< PI_C862.cmd
#!< PI_E816.cmd
iocInit
Starting iocInit
## EPICS R7.0.8.2-DEV
## Rev. R7.0.8.1-142-g144f9756eac4e800f18d
## Rev. Date Git: 2025-02-05 10:16:16 -0600
recGblRecordError: motor_init_record_com(): card does not exist! Illegal field value PV: pi_1:m1 recGblRecordError: motor_init_record_com(): card does not exist! Illegal field value PV: pi_1:m2
motorUtilInit("pi_1:")
# Boot complete
epics>
What am I wrong?
awaiting your reply
Dariush
p.s.: @Matt, following your PIGC2 mod module, I can use it once it will be implemented in official version...
Il 11/07/2025 18:42, Peterson, Kevin M. ha scritto:
Dariush,
The support in motorPI is very limited compared to the support in motorPIGCS2.  I don't know if copying the C-844 support and renaming it for the C-663 will work.  If it does work, it would be difficult to add missing features to the motorPI support, because the drivers are model-1 drivers, which aren't easily extensible.
A simpler approach would be to use one serial port per C-663 and use motorPIGCS2 or do use the old verison of motorPIGCS2 that supports daisy-chaining.
I will attempt to answer your questions:
1. That st.cmd looks ok to me.
2. In the PI_C663.cmd, this line only specifies one controller:
PIC663Setup(1, 10)
I would change it to support two controllers:
PIC663Setup(2, 10)
3. Macro explanations:
N = a macro that is usually only used to set both the motor name (M) and description (DESC) fields to "m$(N)."  This isn't actually a macro that is required by the database and can be exlcuded if none of the values use "$(N)".
M = the motor's name.  The full record name of the motor is "$(P)$(M)"
C = card index (starting from zero)
S = slot index (starting from zero)
For a daisy chain of multi-axis controllers, C is usually the index of the controller and S is usually the index of the motor.  Some controllers, however, are smart enough to know that multiple controllers are daisy chained and and present themselves as a single controller (C=0 for all axes), so the S in that case would range from 0 to (num controllers * num axes per control - 1).
I don't know how the daisy-chain addressing works with the C-663 controller, so I don't know if the motor record for the 2nd axis should have C=0 & S=1 or C=1 and S=0.
Kevin
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room:	+39.06.9403.5248
Lab.:	+39.06.9403.2286
Mob.:	+39.06.9403.8025
Fax.:	+39.06.9403.2597
Re: help requested about motorPI module Dariush Hampai via Tech-talk
Prev: Re: Issues in MCA module with XFlash detector Mark Rivers via Tech-talk
Next: RE: Issues in MCA module with XFlash detector Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: EPNix 25.05 released NICOLE Rémi via Tech-talk
Next: Re: help requested about motorPI module Dariush Hampai via Tech-talk
