1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: documentation for new epics 7 dbLock usage and Redundant IOC software
From: "Baily, Scott A via Tech-talk" <[email protected]>
Date: Thu, 17 Jul 2025 18:32:33 +0000
I’m attempting to update the redundant IOC software to build with EPICS 7. The API for record locking has been changed completely.  One component of the software needs to have the ability to change database links. With EPICS 3.15 this means calling a global lock function and some Add/remove link functions as well as dbLockSetSplit and dbLockSetMerge.  Many of these no longer exist, the new interface to lock a record or multiple records is much simpler, but what functions need to be called when modifying database links? Is there any documentation or examples I can look at?
Are the split and merge calls no longer needed?  Do I need to lock and unlock one or both records before adding or removing links, or do the epics 7 versions of dbAddLink and dbRemoveLink take care of the locking and lockset management?
Re: documentation for new epics 7 dbLock usage and Redundant IOC software Johnson, Andrew N. via Tech-talk
Prev: Re: [External] Support for Edwards nXDS 10i Heinz Junkes via Tech-talk
Next: Re: documentation for new epics 7 dbLock usage and Redundant IOC software Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
