1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Using AD plugins on asyn port
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Pearson, Matthew" <[email protected]>, "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>, Abdalla Ahmad <[email protected]>
Date: Tue, 22 Jul 2025 16:14:17 +0000
You can use an aao (array analog output) record to read array data from another record using the DOL input link and write it through the OUT output link to another record. The DOL and OMSL fields were added to it in EPICS 7.0.7.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 7/22/25, 10:24 AM, "Tech-talk" <[email protected]> wrote:
Apologies, I haven’t used that driver myself, and I assumed it would work like the pvaDriver. Mark is right, seems like you need an extra step to copy the waveform data into ArrayIn. One other option might be an array subroutine record.
Cheers,
Matt
Sent: Tuesday, July 22, 2025 8:43 AM
To: Pearson, Matthew <[email protected]>; [email protected]; Abdalla Ahmad <[email protected]>
Subject: [EXTERNAL] Re: Using AD plugins on asyn port
Hi Abdalla, it is exactly what I need, but it is still unclear how it interfaces with my existing waveform record, i.e. How to pass data from my waveform record to $(P)$(R)ArrayIn. My waveform record already has its INP field set to read input
Hi Abdalla,
·          it is exactly what I need, but it is still unclear how it interfaces with my existing waveform record, i.e. How to pass data from my waveform record to $(P)$(R)ArrayIn. My waveform record already has its INP field set to read input from a compress record doing circular buffer at 200 Hz from the hardware.
You probably need to use some additional code, for example in Python or SNL.  That code will read from your existing waveform record and write to ArrayIn.  It can also configure the other records in NDDriverStdArrays, and decide when to copy the waveform record.  For example, it may only copy when the waveform record is "full", not on each incremental update.
There are examples of Python and IDL code in the NDDriverStdArrays repository.
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Tuesday, July 22, 2025 1:58 AM
[email protected]>; [email protected] <[email protected]>
Subject: RE: Using AD plugins on asyn port
Thanks Matt, it is exactly what I need, but it is still unclear how it interfaces with my existing waveform record, i.e. How to pass data from my waveform record to $(P)$(R)ArrayIn. My waveform record already has its INP field set to read input from a compress record doing circular buffer at 200 Hz from the hardware.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Sent: Monday, July 21, 2025 5:01 PM
To: Abdalla Ahmad <
Hi Abdalla,
This might be what you need:
https://areadetector.github.io/areaDetector/NDDriverStdArrays/NDDriverStdArraysDoc.html
It monitors a waveform record and can turn it into an NDArray, which can then be processed by other areaDetector plugins as needed. It doesn’t connect to the Asyn port that is producing the waveform data directly, but instead sets up a channel access monitor.
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Monday, July 21, 2025 3:14 AM
To:
[email protected]
Subject: [EXTERNAL] Using AD plugins on asyn port
Hi Is there a way to apply AD plugins on a waveform record processed from asyn port without rewriting an asynNDArrayDriver class? i. e. , something to be done in the st. cmd maybe? Best Regards, Abdalla Al-Dalleh Control Engineer SESAME ‍ ‍ ‍ ‍ ‍ ‍
Hi
Is there a way to apply AD plugins on a waveform record processed from asyn port without rewriting an asynNDArrayDriver class? i.e., something to be done in the st.cmd maybe?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
RE: Using AD plugins on asyn port Mark Rivers via Tech-talk
Using AD plugins on asyn port Abdalla Ahmad via Tech-talk
RE: Using AD plugins on asyn port Pearson, Matthew via Tech-talk
RE: Using AD plugins on asyn port Abdalla Ahmad via Tech-talk
Re: Using AD plugins on asyn port Mark Rivers via Tech-talk
Prev: RE: Using AD plugins on asyn port Pearson, Matthew via Tech-talk
Next: RE: Using AD plugins on asyn port Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
