1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Modbus asyn issue with RS485 connection (maybe hardware related)
From: "Heinz Junkes \(FHI\) via Tech-talk" <[email protected]>
To: Mark Rivers via Tech-talk <[email protected]>
Date: Wed, 13 Aug 2025 16:19:05 +0200
we want to operate a motor (https://www.omc-stepperonline.com/de/icl-serie-nema-17-integrierter-rs485-schrittmotor-mit-geschlossenem-regelkreis-0-4nm-56-64oz-in-20-36vdc-mit-14-bit-encoder-icl42-rs06) directly via RS485 (https://jetwaycomputer.com/spec/expansion/ADPIE1COM4.pdf) with modbus.
In order to be able to operate the motor with our hardware setup, we need to set the serial interface to
SER_RS485_ENABLED and SER_RS485_RTS_AFTER_SEND.
We do this via asynSetOption():
asynSetOption("DISCM",0,"rs485_enable", "Y")
asynSetOption("DISCM",0,"rs485_rts_after_send", "Y”)
This can be found in the Linux kernel:
+/* We should do proper H/W transceiver setting before change to RS485 mode */
+static int f81504_rs485_config(struct uart_port *port,
+			       struct serial_rs485 *rs485)
+	u8 setting;
+	u8 *index = (u8 *)port->private_data;
+	struct pci_dev *pci_dev = container_of(port->dev, struct pci_dev, dev);
+	pci_read_config_byte(pci_dev, UART_START_ADDR + UART_OFFSET * *index +
+			UART_MODE_OFFSET, &setting);
+	if (!rs485)
+		rs485 = &port->rs485;
+	else if (rs485->flags & SER_RS485_ENABLED)
+		memset(rs485->padding, 0, sizeof(rs485->padding));
+	else
+		memset(rs485, 0, sizeof(*rs485));
+	/* F81504/508/512 not support RTS delay before or after send */
+	rs485->flags &= SER_RS485_ENABLED | SER_RS485_RTS_ON_SEND;
+	if (rs485->flags & SER_RS485_ENABLED) {
+		/* Enable RTS H/W control mode */
+		setting |= RTS_CONTROL_BY_HW;
+		if (rs485->flags & SER_RS485_RTS_ON_SEND) {
+			/* RTS driving high on TX */
+			setting &= ~RTS_INVERT;
+		} else {
+			/* RTS driving low on TX */
+			setting |= RTS_INVERT;
This means that when SER_RS485_ENABLED (0x01) is set, SER_RS485_RTS_ON_SEND (0x02) is also set automatically.
However, in order to be able to communicate with the motor via Modbus (with our hardware), we need the flag 0x05
(SER_RS485_ENABLED | SER_RS485_RTS_AFTER_SEND) // SER_RS485_RTS_AFTER_SEND == 0x04
We have implemented this as a workaround. If this is of general interest, I will make a pull-request to asyn.
epics@epics-gate14:~/EPICS/epics-support/asyn$ git diff
diff --git a/asyn/drvAsynSerial/drvAsynSerialPort.c b/asyn/drvAsynSerial/drvAsynSerialPort.c
index 1ed6ab47..97078a5d 100644
--- a/asyn/drvAsynSerial/drvAsynSerialPort.c
+++ b/asyn/drvAsynSerial/drvAsynSerialPort.c
@@ -529,6 +529,7 @@ setOption(void *drvPvt, asynUser *pasynUser, const char *key, const char *val)
     else if (epicsStrCaseCmp(key, "rs485_rts_after_send") == 0) {
         if (epicsStrCaseCmp(val, "Y") == 0) {
            tty->rs485.flags |= SER_RS485_RTS_AFTER_SEND;
+           tty->rs485.flags &= ~(SER_RS485_RTS_ON_SEND);
         else if (epicsStrCaseCmp(val, "N") == 0) {
            tty->rs485.flags &= ~(SER_RS485_RTS_AFTER_SEND);
Heinz
Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
Faradayweg 4-6        | VC: https://zoom.fhi.berlin/junkes
D - 14195 Berlin        | E-Mail:        [email protected]
“Sorry I’m a bit late, had a terrible time…
All sort of things cropping up at the last moment. Uh, how are we for time?”
—Zarquon's address to Milliways
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Modbus asyn issue with RS485 connection (maybe hardware related) Heinz Junkes (FHI) via Tech-talk
Prev: Re: synchronizing the value of a read/write record Mark Rivers via Tech-talk
Next: Re: Modbus asyn issue with RS485 connection (maybe hardware related) Heinz Junkes (FHI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Ralph Lange via Tech-talk
