1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access).
From: Gabriel Fedel via Tech-talk <[email protected]>
To: Anders Lindh Olsson <[email protected]>, Heinz Junkes <[email protected]>
Cc: Mark Rivers via Tech-talk <[email protected]>
Date: Fri, 15 Aug 2025 11:03:26 +0000
Hi Heinz,
On phoebus you can access specific fields from NT PVs using /, for example you could access the labels as:
TEST:LLPG/labels
As far I know phoebus still does not implement a way to edit the table itself (but it may exist an interest for it).Using a NTTable you could also use Save and Restore (we are using it here at ESS), but there is some limitations (e.g. not possible to change labels).
if you want to change only one column of the table, you could do something like this:
pvput TEST:LLPG "{'value' : {'Ch':[1,2]}}"
Cheers
Gabriel
From: Tech-talk on behalf of Heinz Junkes via Tech-talk
Sent: Thursday, August 14, 2025 4:25 PM
I have now chosen NTTables instead of a custom structure in order to at least make ArchiverApplianc happy.
(p4ptest) epics@epics-spielwiese:~/FHI/TEST_PVA$ pvinfo TEST:LLPG
TEST:LLPG
Server: 10.0.0.40:5075
Type:
    epics:nt/NTTable:1.0
        string[] labels
        structure value
            ushort[] Ch
            ushort[] Width
            ushort[] Delay
            ushort[] ExtraDly
            ushort[] Atten
        string descriptor
        alarm_t alarm
            int severity
            int status
            string message
        time_t timeStamp
            long secondsPastEpoch
            int nanoseconds
            int userTag
(p4ptest) epics@epics-spielwiese:~/FHI/TEST_PVA$ pvget  TEST:LLPG
TEST:LLPG <undefined>
Ch Width Delay ExtraDly Atten
 1  1000   100       10     1
 2  2000   200       20     2
Unfortunately, I am unable to set individual values in the table using pvput. I can only address everything:
epics@epics-spielwiese:~/FHI/TEST_PVA$ pvput TEST:LLPG value.Ch="[3,4]" value.Width="[111, 222]" value.Delay="[11, 223]"  value.ExtraDly="[11, 22]"  value.Atten="[1331, 2232]”
Old : 2025-08-14 16:22:29.599
 3   111    11       11  1111
 4   222   223       22  2232
New : 2025-08-14 16:22:35.699
 3   111    11       11  1331
 4   222   223       22  2232
I also have no idea how I can then address the individual fields in Phoebus.
Heinz
> On 13. Aug 2025, at 11:24, Anders Lindh Olsson via Tech-talk <[email protected]> wrote:
> Hello,
>  On your question:
> >> Now the question to the group: Is there a better way? And how would you implement my idea?
>  I would map the data structure of the system to EPICS rather than the other way around. So I would compose PVs like FHIFEL:llpg_1:Ch1-Width, FHIFEL-llpg_1:Ch1-Delay, etc.
>   Cheers
> Anders
>  On 2025-08-13, 07:27, "Tech-talk" <[email protected]> wrote:
> Guten Morgen,
>  One thing that has been on my mind for a long time:
>  We have developed our own devices such as llrf generators, pulse generators, etc., which run on a Raspberry Pi or BeagleBone Black as a management interface.
> We then use p4p on that devices and offer the data points in a pva structure tailored to the respective device.
>  E.g.
>  (base) hactar:~ junkes$ pvinfo  FHIFEL:llpg_1
> FHIFEL:llpg_1
> Server: 141.14.134.173:5075
> Type:
>     structure
>         ushort Ch1_Width
>         ushort Ch2_Width
>         ushort Ch1_Delay
>         ushort Ch2_Delay
>         ushort Ch1_ExtraDly
>         ushort Ch2_ExtraDly
>         ushort Ch1_Atten
>         ushort Ch2_Atten
>   epics@felpvagate:~$ pvinfo FHIFEL:bbamp_1
> FHIFEL:bbamp_1
> Server: 10.0.0.110:5075
> Type:
>     structure
>         boolean ITLK
>         boolean TRIG
>         boolean PWR
>         boolean STAT
>         double SWR
>         double FWD
>         double REV
>         byte RFIN
>         double TSET
>         double TMEAS
>         int PIDI
>         int PIDV
>         boolean TTHI
>         boolean PIDLU
>         double PID_PWR
>         boolean CLRER
>  Now we are experiencing some issues with it.
>  1.) The ArchiverAppliance cannot archive these PVs.
> 2.) Our 'old' Save&Restore supports channel access only.
>  How should we best deal with this?
>  My current idea is to implement a service (Python?) that reads this user-defined structure with pva, breaks down the structure into individual NT-pvs and offers these 'individually' via pva (for the Archiver Appliance, for example) and, at the same time, also offers these PVs as ca-PVs for channel access (for our Save&Restore).
>  Danke Heinz
> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> Faradayweg 4-6        | VC: https://zoom.fhi.berlin/junkes
> D - 14195 Berlin        | E-Mail:        [email protected]
> “Sorry I’m a bit late, had a terrible time…
> All sort of things cropping up at the last moment. Uh, how are we for time?”
> —Zarquon's address to Milliways
Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Gabriel Fedel via Tech-talk
Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Heinz Junkes via Tech-talk
Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Anders Lindh Olsson via Tech-talk
Prev: Re: [Ext]Re: Can't use BayerRG8 pixel format with ADSpinnaker Mark Rivers via Tech-talk
Next: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Gabriel Fedel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Heinz Junkes via Tech-talk
