1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access).
From: Heinz Junkes via Tech-talk <[email protected]>
To: Gabriel Fedel <[email protected]>
Cc: Mark Rivers via Tech-talk <[email protected]>
Date: Fri, 15 Aug 2025 17:18:24 +0200
Hallo Gabriel,
Thank you very much for taking the time, and I apologise for only replying now.
I had to finish an application that is due tonight.
When calling pvput TEST:LLPG "{'value' : {'Ch':[1,2]}}”
Unfortunately, I get this error message:
Error: Unable to unwrap Value(id:epics:nt/NTTable:1.0, Value(array([1, 2], dtype=uint16))) with <function NTTable.unwrap at 0x7f2b7b5bc680>
Auf der ’Server-Seite’ sieht es so aus:
(p4ptest) epics@epics-spielwiese:~/FHI/TEST_PVA$ python pvaTest.py
Unexpected
Traceback (most recent call last):
  File "/home/epics/FHI/TEST_PVA/p4ptest/lib/python3.11/site-packages/p4p/server/raw.py", line 21, in value
    return self._unwrap(V)
  File "/home/epics/FHI/TEST_PVA/p4ptest/lib/python3.11/site-packages/p4p/nt/__init__.py", line 231, in unwrap
    for rval in izip(*cols):
TypeError: 'NoneType' object is not iterable
During handling of the above exception, another exception occurred:
  File "/home/epics/FHI/TEST_PVA/p4ptest/lib/python3.11/site-packages/p4p/server/thread.py", line 19, in _on_queue
    M(*args)
  File "/home/epics/FHI/TEST_PVA/pvaTest.py", line 14, in put
    pv.post(op.value(), timestamp=time.time())
  File "/home/epics/FHI/TEST_PVA/p4ptest/lib/python3.11/site-packages/p4p/server/raw.py", line 23, in value
    raise ValueError("Unable to unwrap %r with %r"%(V, self._unwrap))
ValueError: Unable to unwrap Value(id:epics:nt/NTTable:1.0, Value(array([1, 2], dtype=uint16))) with <function NTTable.unwrap at 0x7f2b7b5bc680>
Das Testfile ist angelehnt an ein Beispiel welches ich beim SLAC gefunden hatte:
(p4ptest) epics@epics-spielwiese:~/FHI/TEST_PVA$ cat pvaTest.py
# Python script to generate NTTable
from p4p.nt import NTTable, NTScalar
from p4p.server import Server, ServerOperation
from p4p.server.thread import SharedPV
import time
import numpy as np
class Handler(object):
    """ A handler for dealing with put requests to our test PVs """
    def put(self, pv: SharedPV, op: ServerOperation) -> None:
        """ Called each time a client issues a put operation on the channel using this handler """
        op.done()
table_type = NTTable([('Ch', 'H'),('Width', 'H'), ('Delay', 'H'), ('ExtraDly', 'H'), ('Atten', 'H')])
table_rows = []
table_rows.append({"Ch": 1, "Width": 1000, "Delay": 100, "ExtraDly": 10, "Atten": 1})
table_rows.append({"Ch": 2, "Width": 2000, "Delay": 200, "ExtraDly": 20, "Atten": 2})
initial_table = table_type.wrap(table_rows)
table_pv = SharedPV(nt=table_type, initial=initial_table, handler=Handler(), timestamp=time.time())
server = Server.forever(providers=[{"TEST:LLPG": table_pv}])
Danke Heinz
> On 15. Aug 2025, at 13:03, Gabriel Fedel <[email protected]> wrote:
> Hi Heinz,
> On phoebus you can access specific fields from NT PVs using /, for example you could access the labels as:
> TEST:LLPG/labels
> As far I know phoebus still does not implement a way to edit the table itself (but it may exist an interest for it).Using a NTTable you could also use Save and Restore (we are using it here at ESS), but there is some limitations (e.g. not possible to change labels).
> if you want to change only one column of the table, you could do something like this:
> pvput TEST:LLPG "{'value' : {'Ch':[1,2]}}"
> Cheers
> Gabriel
> From: Tech-talk on behalf of Heinz Junkes via Tech-talk
> Sent: Thursday, August 14, 2025 4:25 PM
> To: Anders Lindh Olsson
> Hi,
> I have now chosen NTTables instead of a custom structure in order to at least make ArchiverApplianc happy.
> (p4ptest) epics@epics-spielwiese:~/FHI/TEST_PVA$ pvinfo TEST:LLPG
> TEST:LLPG
> Server: 10.0.0.40:5075
> Type:
>         string[] labels
>         structure value
>             ushort[] Ch
>             ushort[] Width
>             ushort[] Delay
>             ushort[] ExtraDly
>             ushort[] Atten
>         string descriptor
>         alarm_t alarm
>             int severity
>             int status
>             string message
>         time_t timeStamp
>             long secondsPastEpoch
>             int nanoseconds
>             int userTag
> (p4ptest) epics@epics-spielwiese:~/FHI/TEST_PVA$ pvget  TEST:LLPG
> TEST:LLPG <undefined>
> Ch Width Delay ExtraDly Atten
>  1  1000   100       10     1
>  2  2000   200       20     2
> Unfortunately, I am unable to set individual values in the table using pvput. I can only address everything:
> epics@epics-spielwiese:~/FHI/TEST_PVA$ pvput TEST:LLPG value.Ch="[3,4]" value.Width="[111, 222]" value.Delay="[11, 223]"  value.ExtraDly="[11, 22]"  value.Atten="[1331, 2232]”
> Old : 2025-08-14 16:22:29.599
>  3   111    11       11  1111
>  4   222   223       22  2232
> New : 2025-08-14 16:22:35.699
>  3   111    11       11  1331
>  4   222   223       22  2232
> I also have no idea how I can then address the individual fields in Phoebus.
> Heinz
> > On 13. Aug 2025, at 11:24, Anders Lindh Olsson via Tech-talk <[email protected]> wrote:
> > Hello,
> >  On your question:
> > >> Now the question to the group: Is there a better way? And how would you implement my idea?
> >  I would map the data structure of the system to EPICS rather than the other way around. So I would compose PVs like FHIFEL:llpg_1:Ch1-Width, FHIFEL-llpg_1:Ch1-Delay, etc.
> >   Cheers
> > Anders
> >  On 2025-08-13, 07:27, "Tech-talk" <[email protected]> wrote:
> > Guten Morgen,
> >  One thing that has been on my mind for a long time:
> >  We have developed our own devices such as llrf generators, pulse generators, etc., which run on a Raspberry Pi or BeagleBone Black as a management interface.
> > We then use p4p on that devices and offer the data points in a pva structure tailored to the respective device.
> >  E.g.
> >  (base) hactar:~ junkes$ pvinfo  FHIFEL:llpg_1
> > FHIFEL:llpg_1
> > Server: 141.14.134.173:5075
> > Type:
> >     structure
> >         ushort Ch1_Width
> >         ushort Ch2_Width
> >         ushort Ch1_Delay
> >         ushort Ch2_Delay
> >         ushort Ch1_ExtraDly
> >         ushort Ch2_ExtraDly
> >         ushort Ch1_Atten
> >         ushort Ch2_Atten
> >   epics@felpvagate:~$ pvinfo FHIFEL:bbamp_1
> > FHIFEL:bbamp_1
> > Server: 10.0.0.110:5075
> > Type:
> >     structure
> >         boolean ITLK
> >         boolean TRIG
> >         boolean PWR
> >         boolean STAT
> >         double SWR
> >         double FWD
> >         double REV
> >         byte RFIN
> >         double TSET
> >         double TMEAS
> >         int PIDI
> >         int PIDV
> >         boolean TTHI
> >         boolean PIDLU
> >         double PID_PWR
> >         boolean CLRER
> >  Now we are experiencing some issues with it.
> >  1.) The ArchiverAppliance cannot archive these PVs.
> > 2.) Our 'old' Save&Restore supports channel access only.
> >  How should we best deal with this?
> >  My current idea is to implement a service (Python?) that reads this user-defined structure with pva, breaks down the structure into individual NT-pvs and offers these 'individually' via pva (for the Archiver Appliance, for example) and, at the same time, also offers these PVs as ca-PVs for channel access (for our Save&Restore).
> >  Danke Heinz
> > Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> > Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> > Faradayweg 4-6        | VC: https://zoom.fhi.berlin/junkes
> > D - 14195 Berlin        | E-Mail:        [email protected]
> > “Sorry I’m a bit late, had a terrible time…
> > All sort of things cropping up at the last moment. Uh, how are we for time?”
> > —Zarquon's address to Milliways
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Gabriel Fedel via Tech-talk
Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Heinz Junkes via Tech-talk
Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Anders Lindh Olsson via Tech-talk
Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Heinz Junkes via Tech-talk
Prev: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Gabriel Fedel via Tech-talk
Next: Compatibility issues between the Eurotherm 2000 series and the EPC3008 LONG FENG via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Gabriel Fedel via Tech-talk
