1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: dinosaur question: is there a command to alias another commend in a (3.13.8) startup file?
From: Maren Purves via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 20 Aug 2025 11:52:05 -1000
Thanks Andrew, no, I did not try that, I'll do that  the next time I
have a chance to.
Otherwise I'll just have to get that  function out of the code where I
found it and compile and load  in.
Maren
On Wed, Aug 20, 2025 at 3:52 AM Johnson, Andrew N. <[email protected]> wrote:
> Hi Maren,
> This may be just too easy, but have you tried
>    shutdown = reboot
> which might just work on VxWorks.
> If not you can of course load a compiler C function to be the alias.
> HTH,
> - Andrew
> __
> Intelligence isn’t measured by what you know, but by what you do when you don't know. Learning begins when you’re confused; when you reach the edge of your knowledge and plunge into new territory, taking your brain to a place it’s never been before.
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Maren Purves via Tech-talk <[email protected]>
> Sent: Wednesday, August 20, 2025 3:54:09 AM
> To: EPICS tech-talk <[email protected]>
> Subject: dinosaur question: is there a command to alias another commend in a (3.13.8) startup file?
> Hi all,
> hoping to get to upgrading at least some stuff at some point, but
> we're still running  mostly 3.13.8 on VxWorks 5.5.
> A now retired former line manager of  mine implemented a shutdown
> command that in addition to rebooting a crate also disconnects the
> serial lines on it.
> Now our telescope operators (all but one are new hires) have been
> told to use shutdown but that  doesn't work on the crates where it
> isn't loaded because the care doesn't have serial lines. I know of one
> where we have to load code that is otherwise no longer used just
> because of the shutdown function being embedded in it.
> If there is and easy
> alias shutdown reboot
> I can put in the startup file (not a std.cmd file but a startup.vws
> file  - for those who are only used to newer systems) that would be
> great but neither Google's AI nor any recent documentation mentions
> any of anything like this.
> TIA,
> Maren
> (I may just have to teach the telescope operators, I guess)
dinosaur question: is there a command to alias another commend in a (3.13.8) startup file? Maren Purves via Tech-talk
Re: dinosaur question: is there a command to alias another commend in a (3.13.8) startup file? Johnson, Andrew N. via Tech-talk
Prev: Re: synchronizing the value of a read/write record Thomas, Patrick via Tech-talk
Next: IOC PVs intermittently flicker between values and LINK INVALID Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: dinosaur question: is there a command to alias another commend in a (3.13.8) startup file? Johnson, Andrew N. via Tech-talk
