1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: 4-wire sensing device
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>
Cc: Michael Sintschuk <[email protected]>
Date: Fri, 22 Aug 2025 16:10:58 +0000
I’ve been quite impressed by the Acromag BusWorks NT devices we’ve bought recently which are expandable and can mix different I/O types, one of which is a 4-channel RTD input. They have a wide range of other input and output modules, and the base units support Modbus/TCP, Ethernet/IP and ProfiNet. I saw announcements about OPC-UA, MQTT and RESTful protocol support recently too. Their engineering documentation is great, and I've had no difficulty controlling them from the EPICS Modbus driver and Asyn device support.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 8/22/25, 9:46 AM, "Tech-talk" <[email protected]> wrote:
We have used the Measurement Computing USB-TEMP and USB-TEMP-AI. It costs about $600.
They can measure thermcouples, RTD, semiconductor, and thermistor sensors.  There is EPICS support in
Sent from my iPhone
On Aug 22, 2025, at 9:07 AM, Pearson, Matthew via Tech-talk <[email protected]> wrote:
Hi Michael,
We’ve used 4-wire PT100 RTDs with the Lakeshore 224, which has support for 12 channels. It’s easy to interface to and setup.
https://www.lakeshore.com/products/categories/overview/temperature-products/cryogenic-temperature-monitors/model-224-temperature-monitor
We use it for both cryogenic applications and also room temperature measurements.
It has good EPICS support, although I’m not seeing any published support on the EPICS website. I can send you a copy of our local support if you need it.
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Sintschuk, Michael via Tech-talk
Sent: Friday, August 22, 2025 5:11 AM
Subject: [EXTERNAL] 4-wire sensing device
Dear all, I would like to know what devices you are using for measuring 4-wire RTDs (temperatur), that -of course- have EPICS-support. For a long time, we used the multimeter Keithley K2700, until it broke. The Keithley DAQ6510/7700 seems to
Dear all,
For a long time, we used the multimeter Keithley K2700, until it broke. The Keithley DAQ6510/7700 seems to be the successor of the K2700 that would fit our needs. But I wonder if there are other systems in use…
We don’t actually need high measurement accuracy, but at least 10 channels would be good.
Best regards
Michael
Bundesanstalt für Materialforschung und –prüfung (BAM)
M.Eng. Michael Sintschuk
8.5 - X-ray Imaging
Unter den Eichen 87
12205 Berlin
GERMANY
Phone: +49 30 8062-15063
E-Mail:
[email protected]
Re: 4-wire sensing device Mark Rivers via Tech-talk
Prev: Re: 4-wire sensing device Mark Rivers via Tech-talk
Next: Are USB3 Vision cameras any better than GigE Vision cameras? Henrique F. Simoes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
