1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Are USB3 Vision cameras any better than GigE Vision cameras?
From: "Engbretson, Mark S. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>, "Henrique F. Simoes" <[email protected]>
Cc: Ana Clara de Souza Oliveira <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 Aug 2025 16:14:41 +0000
A common issue on both of these cameras are overheating, especially with PoE GigE models – but I have seen the same problems with USB3 models. In that case, both types of hardware jam or drop offline throwing led blinks patterns that basically show an issue. You either then have to put more active cooling in (like a fan), or a mount that actively sinks heat.  While I have seen some units seem to work at 80 degrees C, other seem to start falling offline at slightly over 50 C. Not sure that I have even seen issues when the temps are kept below 50 C.
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Monday, August 25, 2025 10:47 AM
To: Henrique F. Simoes <[email protected]>; [email protected]
Hi Henrique,
I have been using both USB3 Vision and GigE Vision cameras for many years.  In general, I have found both to be very stable, though GigE Vision cameras sometimes have occasional dropped frames.
I have used USB3 Vision for cameras that require greater bandwidth than GigE can support, for example this Grasshopper3 camera
https://www.teledynevisionsolutions.com/products/grasshopper3-usb3/?model=GS3-U3-23S6M-C&vertical=machine%20vision&segment=iis
  • To me, they have the drawback of requiring a computer right next to it,
That is not really true.  I use this active USB3 extender cable, and the distance between the camera and the computer can be more than 25 meters (20m for the extender cable plus 3m for the normal USB-3 cable).  The above camera runs at the full USB3 rate with no problems.
https://www.amazon.com/SIIG-Active-Repeater-20-Meters-JU-CB0811-S1/dp/B0053YLYLC?th=1
GigE cameras can have issues if they are sharing network bandwidth with many devices, but in general I have found them to be quite reliable.  You can eliminate virtually all issues by using a dedicated NIC and direct connection to the camera.  That is less convenient than using switches, but it allows greater distances than USB3.  I am running my tomography data collection with a 10G Ethernet camera on a dedicated NIC and have no problems with dropped packets or dropped frames.
https://www.teledynevisionsolutions.com/products/oryx-10gige/?model=ORX-10GS-51S5M-C&vertical=machine%20vision&segment=iis
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Henrique F. Simoes via Tech-talk
Sent: Monday, August 25, 2025 9:40 AM
To: [email protected]
Subject: Are USB3 Vision cameras any better than GigE Vision cameras?
Hi folks,
I've been recently asked whether we should be choosing USB3 Vision cameras as a replacement for GigE Vision cameras. This inquiry comes in the context of disbelief on GigE cameras by users due to their instability. (This is somewhat related to that topic in the other thread
[1].)
Does anyone have had better experience with USB cameras over Ethernet ones? Any comment regarding their comparison will be helpful to discuss this topic internally, as we don't have any of those cameras in operation nowadays.
To me, they have the drawback of requiring a computer right next to it, which goes against our current effort of removing them for Ethernet ones.
Thanks in advance.
[1] epics.anl.gov/tech-talk/2025/msg00632.php
Henrique F. Simões
Control Software Group (SwC)
Brazilian Synchrotron Light Laboratory (LNLS) Brazilian Center for Research in Energy and Materials (CNPEM)
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Are USB3 Vision cameras any better than GigE Vision cameras? Henrique F. Simoes via Tech-talk
RE: Are USB3 Vision cameras any better than GigE Vision cameras? Mark Rivers via Tech-talk
Prev: RE: Are USB3 Vision cameras any better than GigE Vision cameras? Mark Rivers via Tech-talk
Next: Re: Are USB3 Vision cameras any better than GigE Vision cameras? Henrique F. Simoes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
