Hi Mark,
On Mon Aug 25, 2025 at 1:14 PM -03, Engbretson, Mark S. wrote:
> A common issue on both of these cameras are overheating, especially
> with PoE GigE models - but I have seen the same problems with USB3
> models.
Okay. It makes sense to happen to both of them.
> In that case, both types of hardware jam or drop offline throwing led
> blinks patterns that basically show an issue.
One problem is that most cameras we have deployed, which are Basler
acA1300-75gm, don't have a status LED. When they are online, we can
query their TemperatureStatus GenICam feature to see if it is "Error",
"Critical" or "OK", or their internal temperature measurement. I haven't
seen any of them change their status before going offline; although we
still have a pending task to monitor this more thoroughly.
> You either then have to put more active cooling in (like a fan), or a
> mount that actively sinks heat.
That's something we don't have. I'm curious to know if Mark Rivers needs
these on his cameras as well.
I cannot forget John Dobbins' comment about thermal connection of some
models [1], which made myself question what's the best way to cool them
if that's really our main issue.
> While I have seen some units seem to work at 80 degrees C,
The ones we use are supposed to reach almost that temperature level
without failing; they seem to keep below their limit as I've mentioned
in the other thread [2].
> other seem to start falling offline at slightly over 50 C.
Do these signal they are falling offline because of temperature as well?
> Not sure that I have even seen issues when the temps are kept below 50
> C.
What is the average temperature in this case?
Thanks for your comments ;)
[1] epics.anl.gov/tech-talk/2025/msg00639.php
[2] epics.anl.gov/tech-talk/2025/msg00638.php
Henrique F. Simões
Control Software Group (SwC)
Brazilian Synchrotron Light Laboratory (LNLS)
Brazilian Center for Research in Energy and Materials (CNPEM)
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- RE: Are USB3 Vision cameras any better than GigE Vision cameras? Mark Rivers via Tech-talk
- RE: Are USB3 Vision cameras any better than GigE Vision cameras? Engbretson, Mark S. via Tech-talk
- Are USB3 Vision cameras any better than GigE Vision cameras? Henrique F. Simoes via Tech-talk
Re: Are USB3 Vision cameras any better than GigE Vision cameras? Henrique F. Simoes via Tech-talk
<2025>
2026
<2025>
2026
