1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: pvxput to an array
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Pierrick Hanlet <[email protected]>
Date: Wed, 10 Sep 2025 16:01:38 -0700
On 9/10/25 14:46, Pierrick Hanlet via Tech-talk wrote:
Greetings all,
I am unable to write an array with pvxput.  I'm hoping that I'm using
the wrong syntax.
"pvxput" from current releases of PVXS have only limited support for put to scalars.  This is why I still recommend sticking with "pvput" from pvAccessCPP.
However, if you would like to test:
https://github.com/epics-base/pvxs/pull/63
would add support for JSON style assignments.  eg.
pvxput pv:name "[1,2,3]"
pvxput pv:name "value.colA=[1,2,3]" "value.colB=[1,2,3]"
Re: pvxput to an array Pierrick Hanlet via Tech-talk
Prev: pvxput to an array Pierrick Hanlet via Tech-talk
Next: Re: pvxput to an array Pierrick Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
