1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: pvxput to an array
From: Pierrick Hanlet via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 10 Sep 2025 23:04:33 +0000
Thank you Michael,
Pierrick
On 9/10/25 18:01, Michael Davidsaver wrote:
[EXTERNAL] – This message is from an external sender
On 9/10/25 14:46, Pierrick Hanlet via Tech-talk wrote:
Greetings all,
I am unable to write an array with pvxput.  I'm hoping that I'm using
the wrong syntax.
"pvxput" from current releases of PVXS have only limited support for put to scalars.  This is why I still recommend sticking with "pvput" from pvAccessCPP.
However, if you would like to test:
https://github.com/epics-base/pvxs/pull/63
would add support for JSON style assignments.  eg.
pvxput pv:name "[1,2,3]"
pvxput pv:name "value.colA=[1,2,3]" "value.colB=[1,2,3]"
Pierrick Hanlet
+1-630-840-5555  office
+1-312-687-4980  mobile
=== "Whether you think you can or think you can't, either way, you're correct" -- Henry Ford
pvxput to an array Pierrick Hanlet via Tech-talk
Re: pvxput to an array Michael Davidsaver via Tech-talk
Prev: Re: pvxput to an array Michael Davidsaver via Tech-talk
Next: modbus instruments don't provide the correct connection status using asyn check Antonio Moschini via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
