That should definitely work.
Please send:
- The complete output when you rebuild the IOC application.
- The complete output when the IOC boots
- The output of the iocsh "help" command after the IOC boots.
-----Original Message-----
Sent: Thursday, September 18, 2025 10:43 AM
To: Mark Rivers <[email protected]>; [email protected]
Subject: Re: Problem with drvAsynIPPortConfigure
Hi Mark,
the base.dbd already there... however chanking the order the problem still remain...
PROD_IOC = mdrive_1IOC
# mdrive_1IOC.dbd will be created and installed DBD += mdrive_1IOC.dbd
# mdrive_1IOC.dbd will be made up from these files:
mdrive_1IOC_DBD += base.dbd
# Include dbd files from all support applications:
#mdrive_1IOC_DBD += xxx.dbd
mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_DBD += drvAsynIPPort.dbd
mdrive_1IOC_DBD += stream-base.dbd
# Add all the support libraries needed by this IOC #mdrive_1IOC_LIBS += xxx mdrive_1IOC_LIBS += stream mdrive_1IOC_LIBS += asyn
Il 18/09/2025 17:37, Mark Rivers ha scritto:
> Hi Dariush,
> I think you have the order of your dbd files wrong. They should be in this order:
> Is stream-base.dbd part of the StreamDevice module, or is that something local to your site? The files you listed did not include base.dbd, which should come first. So I think it should really be:
> mdrive_1IOC_DBD += stream.dbd
> Mark
> From: Dariush Hampai <[email protected]>
> Sent: Thursday, September 18, 2025 10:21 AM
> To: [email protected]; Mark Rivers <[email protected]>
> Subject: Problem with drvAsynIPPortConfigure
> hi Community,
> I'm writing an IOC for industrial motor driver:
> I prepare the IOC, in particular:
> 1) in the configure/RELASE there is
> SUPPORT=$(EPICS_BASE)/synApps_6_3/support
> ASYN=$(SUPPORT)/asyn-R4-44-2
> STREAM=$(SUPPORT)/StreamDevice-2-8-24
> EPICS_BASE = /home/xlabsrv2/epics
> 2) in the mdrive_1IOC/src/Makefile there is mdrive_1IOC_DBD +=
> stream-base.dbd mdrive_1IOC_DBD += drvAsynIPPort.dbd mdrive_1IOC_DBD
> += asyn.dbd
> 3) in the mdrive_1IOC/Db/Makefile there is DB += mdrive_1IOC.proto DB
> += mdrive_1IOC.db DB += mdrive_1IOC.val
> 4) in the mdrive_1IOC/Db/mdrive_1IOC.val there is file db/mdrive_1IOC.db {
> pattern { card, axis, ASYNPORT, MOT, EGU, homing, MRES, direct }
> { 1, 1 , "ip_x", "mdrive_x", mm, 1, 411, + } }
> 5) in the st.cmd there is
> epicsEnvSet ("STREAM_PROTOCOL_PATH", "${TOP}/db") epicsEnvSet
> ("PORT_mdrive_x", "ip_x")
> drvAsynIPPortConfigure($(PORT_mdrive_x), "100.100.0.23:503")
> asynOctetSetInputEos($(PORT_mdrive_x),0,"\n\r")
> asynOctetSetOutputEos($(PORT_mdrive_x),0,"\n\r")
> asynSetTraceMask($(PORT_mdrive_x),-1,0x9);
> asynSetTraceIOMask($(PORT_mdrive_x),-1,0x2)
> These are the configurations. After make (all is ok), executing the
> st.cmd I receive the following error
> [xlabsrv2@xlabsrv2 iocmdrive_1IOC]$ ./st.cmd
> #!../../bin/linux-x86_64/mdrive_1IOC
> < envPaths
> epicsEnvSet("IOC","iocmdrive_1IOC")
> epicsEnvSet("TOP","/home/xlabsrv2/epics/IOCs/mdrive_1IOC")
> epicsEnvSet("SUPPORT","/home/xlabsrv2/epics/synApps_6_3/support")
> epicsEnvSet("ASYN","/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-4
> 4-2")
> epicsEnvSet("STREAM","/home/xlabsrv2/epics/synApps_6_3/support/StreamD
> evice-2-8-24")
> epicsEnvSet("EPICS_BASE","/home/xlabsrv2/epics")
> cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC"
> "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/db")
> epicsEnvSet ("PORT_mdrive_x", "ip_x")
> #X Axis
> drvAsynIPPortConfigure(ip_x, "100.100.0.23:503") ERROR st.cmd line 36: Command drvAsynIPPortConfigure not found.
> asynOctetSetInputEos(ip_x,0,"\n\r")
> ERROR st.cmd line 37: Command asynOctetSetInputEos not found.
> asynOctetSetOutputEos(ip_x,0,"\n\r")
> ERROR st.cmd line 38: Command asynOctetSetOutputEos not found.
> asynSetTraceMask(ip_x,-1,0x9);
> ERROR st.cmd line 40: Command asynSetTraceMask not found.
> asynSetTraceIOMask(ip_x,-1,0x2)
> ERROR st.cmd line 41: Command asynSetTraceIOMask not found.
> ## Register all support components
> dbLoadDatabase "dbd/mdrive_1IOC.dbd"
> mdrive_1IOC_registerRecordDeviceDriver pdbbase ## Load record
> instances
> #dbLoadRecords("db/mdrive_1IOC.db","user=xlabsrv2")
> dbLoadTemplate("db/mdrive_1IOC.val")
> dbLoadTemplate: Too many values given, line 14.
> cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC"
> iocInit
> Starting iocInit
> ## EPICS R7.0.8.2-DEV
> ## Rev. R7.0.8.1-142-g144f9756eac4e800f18d
> ## Rev. Date Git: 2025-02-05 10:16:16 -0600
> 2025/09/18 16:04:01.785392 _main_ Cannot find a bus named 'ip_x' for 'mdrive_x:model'
> 2025/09/18 16:04:01.785498 _main_ mdrive_x:model: Can't attach to bus
> ip_x 0
> 2025/09/18 16:04:01.785517 _main_ mdrive_x:model: Record
> initialization failed
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq sncxxx,"user=xlabsrv2"
> epics>
> searching in previous threads I found missing the "drvAsynIPPort.dbd"
> in src/Makefile, but I already put it. Moreover I use "make clean
> all", and (to be sure) in this case I also remove db, dbd, and lib
> folders to restart with a clean make
> where ma I wrong?
> thank you in advance!!!
> Dariush
> p.s.: all other IOCs using drvAsynIPPortConfigure working properly...
> Dr. Dariush Hampai, PhD
> INFN - LNF
> X-Lab Frascati
> Via E. Fermi, 54 (ex 40)
> I-00044 Frascati (RM)
> Italy
> Mail Address:
> XLab-Frascati
> LNF-INFN
> Casella Postale 13
> Frascati (RM)
> Italy
> Room: +39.06.9403.5248
> Lab.: +39.06.9403.2286
> Mob.: +39.06.9403.8025
> Fax.: +39.06.9403.2597
INFN - LNF
X-Lab Frascati
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
- Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
- RE: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
- Re: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Michael Davidsaver via Tech-talk
<2025>
2026
Re: Problem with drvAsynIPPortConfigure Henrique F. Simoes via Tech-talk
<2025>
2026
