1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: quadEM FFP plugin update issues
From: "Ha, Kiman via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 27 Sep 2025 16:28:54 +0000
Hi Mark,
Thank you for the quick update.
Before proceeding with your suggestion, I checked the other waveforms and confirmed that only the FFTAbsValue has stopped updating.
The rest are functioning normally.
I’ll follow up with your recommendation and investigate it and will update.
Kiman
Sent: Saturday, September 27, 2025 12:22 PM
To: Ha, Kiman <[email protected]>; [email protected]
Hi Kiman, I just tested on my system, and I can’t reproduce the problem. This is not related to the issue of the plugin updates stopping, but I would suggest that you change the number of points from 1000 to 1024. I think the “beats”
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Kiman,
This is not related to the issue of the plugin updates stopping, but I would suggest that you change the number of points from 1000 to 1024.  I think the “beats” you see in frequency are artifacts of the fact that the number of points is not a power of 2.
This is what my Y position FFT looks like:
The first thing to do is open the detailed screens for that FFT plugin.  This is what I see with “More/FFT plugin”.  Note that Array rate=10 Hz, the execution time is 0.474 ms, and the array counter is incrementing at 10 Hz.  Are these values updating on your screen?
This is what I see when I press the More/NDPluginBase Full”  on the screen above:
The next thing to determine is whether Channel Access updates of the waveform record are being sent.  The way to test this is with camonitor.  This is what I see with camonitor on the X and Y positions, asking only for the first 2 points in the waveform.
(base) [epics@corvette ~]$ camonitor -#2 13IDA:QE1:FFT:PosX:FFTAbsValue
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.331851 2 0 1.15078
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.431627 2 0 1.15078
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.531824 2 0 1.15078
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.631831 2 0 0.822881
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.731868 2 0 0.822881
^C
(base) [epics@corvette ~]$ camonitor -#2 13IDA:QE1:FFT:PosY:FFTAbsValue
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:34.831667 2 0 0.326255
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:34.931805 2 0 0.326255
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:35.031571 2 0 0.0809308
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:35.131777 2 0 0.0809308
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:35.231808 2 0 0.0809308
They are both updating at 10 Hz, as expected.
What do you see when you run this camonitor command on your X and X FFT positions?
The next thing to do is use “ps” to list the threads with names that contain FFT.  This is what I see:
(base) [epics@corvette ~]$ ps -eL | grep FFT
1737089 1737178 pts/14   00:00:00 QE1_FFT1_update
1737089 1737181 pts/14   00:00:00 QE1_FFT2_update
1737089 1737184 pts/14   00:00:00 QE1_FFT3_update
1737089 1737187 pts/14   00:00:00 QE1_FFT4_update
1737089 1737190 pts/14   00:00:00 QE1_FFT5_update
1737089 1737193 pts/14   00:00:00 QE1_FFT6_update
1737089 1737196 pts/14   00:00:00 QE1_FFT7_update
1737089 1737199 pts/14   00:00:00 QE1_FFT8_update
1737089 1737202 pts/14   00:00:00 QE1_FFT9_update
1737089 1737205 pts/14   00:00:00 QE1_FFT10_updat
1737089 1737208 pts/14   00:00:00 QE1_FFT11_updat
1737089 1737301 pts/14   00:00:03 QE1_FFT1_Plugin
1737089 1737303 pts/14   00:00:04 QE1_FFT2_Plugin
1737089 1737305 pts/14   00:00:04 QE1_FFT3_Plugin
1737089 1737307 pts/14   00:00:04 QE1_FFT4_Plugin
1737089 1737309 pts/14   00:00:04 QE1_FFT5_Plugin
1737089 1737311 pts/14   00:00:04 QE1_FFT6_Plugin
1737089 1737313 pts/14   00:00:04 QE1_FFT7_Plugin
1737089 1737315 pts/14   00:00:04 QE1_FFT8_Plugin
1737089 1737317 pts/14   00:00:04 QE1_FFT9_Plugin
1737089 1737319 pts/14   00:00:04 QE1_FFT10_Plugi
1737089 1737321 pts/14   00:00:04 QE1_FFT11_Plugi
Note that there are 11 FFT threads with _update in the name and 11 with _Plugin in the name.  What do you see?  Are all the threads there?
Let me know the results of these tests on your system.
Sent: Friday, September 26, 2025 5:59 PM
To: [email protected]
Cc: Mark Rivers <[email protected]>
Subject: quadEM FFP plugin update issues
Hi Mark,
We are using a new NSLS2EM hardware setup with the quadEM IOC.
One of our IOCs has an issue where the FFT plugin stops updating shortly after the IOC is started.
Although the FFT plugin has stopped updating, the circular buffer index continues to update.
Time-domain display continues to work without any problems.
Do you have any suggestions or recommendations to help resolve this issue?
Is it possible to restart the FFT plugin without rebooting the IOC?
See plot the PosX FFT is still running but the PosY is stopped.
Kiman
quadEM FFP plugin update issues Ha, Kiman via Tech-talk
RE: quadEM FFP plugin update issues Mark Rivers via Tech-talk
Prev: RE: quadEM FFP plugin update issues Mark Rivers via Tech-talk
Next: EPICS CA and PVA across subnets Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: RE: quadEM FFP plugin update issues Ha, Kiman via Tech-talk
