1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Fast stream-device IOC suddenly disconnects
From: "Zimoch, Dirk via Tech-talk" <[email protected]>
To: Abdalla Ahmad <[email protected]>
Date: Sun, 28 Sep 2025 11:38:16 +0000
Hello Abdalla
Please provide records and protocol file. Can you reproduce this with a simulated device that you can provide as well?
Dirk
Am 28.09.2025 um 13:08 schrieb Abdalla Ahmad via Tech-talk <[email protected]>:
Hi
We have a device streaming data at 200 Hz controlled with stream device, parses the streamed data and writes to corresponding PVs. The problem is that every day or two, the readings freeze. At first I had to restart the IOC but I noticed that the IOC does not show any error so I re-connect the asyn port through writing 0 to the CNCT field and it worked. The st.cmd file has the port configured:
drvAsynIPPortConfigure(“PORT”, “ip-address:port-number”, 0, 0, 0)
What could be the issue here? I am using EPICS base 7.0.9 and latest version of all modules.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
RE: Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Prev: Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Next: RE: Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
