Hello Dirk
I have attached the protocol files as well as two databases, the IOC first reads the raw data and then process a group of PVs sequentially
as seen by the chain of forward-links. When the issue happens, the first PV in the chain “:Raw$(CH)” is frozen.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Please provide records and protocol file. Can you reproduce this with a simulated device that you can provide as well?
Hi
We have a device streaming data at 200 Hz controlled with stream device, parses the streamed data and writes to corresponding PVs. The problem is that every day or two, the readings freeze. At first I had to
restart the IOC but I noticed that the IOC does not show any error so I re-connect the asyn port through writing 0 to the CNCT field and it worked. The st.cmd file has the port configured:
drvAsynIPPortConfigure(“PORT”, “ip-address:port-number”, 0, 0, 0)
What could be the issue here? I am using EPICS base 7.0.9 and latest version of all modules.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
controller.db
Description: controller.db
vibration.proto
Description: vibration.proto
- Re: Fast stream-device IOC suddenly disconnects Zimoch, Dirk via Tech-talk
- Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Re: Fast stream-device IOC suddenly disconnects Mark Rivers via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
