1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: quadEM FFP plugin update issues
To: "Ha, Kiman" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Gavrilov, Dmitri" <[email protected]>
Date: Mon, 29 Sep 2025 20:46:58 +0000
Hi Kiman,
  • The Time series works fine and FFT real and imaginary values are keep updating.
  • My question is why only the FFTAbsValue stopping?
I think you need to be careful with how you describe the behavior.  You say it “stopped updating”, but I don’t think that is true.  You attached the monitor for PosY:FFTAbsValue.  It did not stop updating, it is continuing to send updates at 10 Hz.
[kha@xf03idc-ws1 ~]$ camonitor -#2 XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:20.680943 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:20.780961 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:20.880687 2 0 nan
The problem is that at least the first value is a NAN.  You should monitor more of the values and see if they are all NAN.   You should also monitor Current3:FFTAbsValue to make sure it is still updating, but the values are also NAN.
I think the real question is why the values are NAN.  This is the code that computes the FFTAbs:
https://github.com/areaDetector/ADCore/blob/99fa6bf4181aa1c9485a9d951331006a48e700b6/ADApp/pluginSrc/NDPluginFFT.cpp#L134
    pPvt->FFTAbsValue [j] = sqrt((pPvt->FFTComplex[2*j]   * pPvt->FFTComplex[2*j] +
                            pPvt->FFTComplex[2*j+1] * pPvt->FFTComplex[2*j+1])) / pPvt->nTimeX;
A NAN result will happen if the value passed to sqrt is negative, or if pPvt->nTimeX is 0.  Since the value passed to sqrt is the sum of 2 numbers squared that should never be negative.  I don’t see how pPvt->nTimeX would be 0, but perhaps it is.
You may need to add debugging code there to see why you the FFTAbs calculation starts returning NAN.
Sent: Monday, September 29, 2025 3:13 PM
To: Mark Rivers <[email protected]>; [email protected]
Cc: Gavrilov, Dmitri <[email protected]>; Wlodek, Jakub <[email protected]>
Hi Mark,
Yes, Ch3 current FFTAbsValue and Y position FFTAbsValue update stopped.
Sent: Monday, September 29, 2025 3:36 PM
To: Ha, Kiman <[email protected]>; [email protected]
Hi Kiman, Canmonitor shows that XF: 03IDC-BI{EM: 1}FFT: PosY: FFTAbsValue is still updating at 10 Hz, it is not stopped. However, the data is all NAN, so the problem appears to be bad data from the BPM. Note that Vertical Current 4 FFT is fine,
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Kiman,
Canmonitor shows that XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue is still updating at 10 Hz, it is not stopped.  However, the data is all NAN, so the problem appears to be bad data from the BPM.
Note that Vertical Current 4 FFT is fine, but Current 3 FFT is not.  That looks like perhaps Current 3 stopped working.  You should include Current3 and Current4 scalar PVs your CA monitor to see if perhaps Current3 stopped returning valid values.
When this happens also grab a screenshot of the Current3 time series.
Sent: Monday, September 29, 2025 2:19 PM
Hi Mark,
After ~20 hours later it happened again PosY.FFTAbs stopped:
I changed FFT length 1024.
After stop waveform data shows “NaN“, however array count is still running.
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:20.981006 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.082019 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.180937 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.281095 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.381122 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.481108 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.580926 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.681254 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.781217 2 0 nan
XF:03IDC-BI{EM:1}FFT:PosY:FFTAbsValue 2025-09-29 15:06:21.881178 2 0 nan
^C
[kha@xf03idc-ws1 ~]$ camonitor -#2 XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue
XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue 2025-09-29 15:08:20.080831 2 0 308.386
XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue 2025-09-29 15:08:20.181127 2 0 136.118
XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue 2025-09-29 15:08:20.281480 2 0 473.483
XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue 2025-09-29 15:08:20.380783 2 0 205.761
XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue 2025-09-29 15:08:20.481021 2 0 191.585
XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue 2025-09-29 15:08:20.581142 2 0 258.867
XF:03IDC-BI{EM:1}FFT:PosX:FFTAbsValue 2025-09-29 15:08:20.681860 2 0 216.273
$ ps -eL | grep FFT
   5138   10557 pts/65   00:00:00 FFT1_updateQueu
   5138   12216 pts/65   00:00:00 FFT1_Plugin_1
   5146   10581 pts/67   00:00:00 FFT1_updateQueu
   5146   12045 pts/67   00:00:00 FFT1_Plugin_1
   5151    9999 pts/58   00:00:00 FFT1_updateQueu
   5151   12645 pts/58   00:00:00 FFT1_Plugin_1
   5339   10931 pts/80   00:00:00 FFT1_updateQueu
   5339   11756 pts/80   00:00:00 FFT1_Plugin_1
   5342    9988 pts/82   00:00:00 FFT1_updateQueu
   5342   12128 pts/82   00:00:00 FFT1_Plugin_1
   5343   10543 pts/79   00:00:00 FFT1_updateQueu
   5343   12733 pts/79   00:00:00 FFT1_Plugin_1
   5348    9984 pts/89   00:00:00 FFT1_updateQueu
   5348   11941 pts/89   00:00:00 FFT1_Plugin_1
   5349    9996 pts/85   00:00:00 FFT1_updateQueu
   5349   11632 pts/85   00:00:00 FFT1_Plugin_1
   5352    9993 pts/83   00:00:00 FFT1_updateQueu
   5352   12824 pts/83   00:00:00 FFT1_Plugin_1
   5489    9990 pts/103  00:00:00 FFT1_updateQueu
   5489   12418 pts/103  00:00:00 FFT1_Plugin_1
   6501   10946 pts/105  00:00:00 FFT1_updateQueu
   6501   12510 pts/105  00:00:00 FFT1_Plugin_1
1574116 1574229 pts/81   00:00:00 NSLS2_EM_FFT1_u
1574116 1574232 pts/81   00:00:00 NSLS2_EM_FFT2_u
1574116 1574235 pts/81   00:00:00 NSLS2_EM_FFT3_u
1574116 1574238 pts/81   00:00:00 NSLS2_EM_FFT4_u
1574116 1574241 pts/81   00:00:00 NSLS2_EM_FFT5_u
1574116 1574244 pts/81   00:00:00 NSLS2_EM_FFT6_u
1574116 1574247 pts/81   00:00:00 NSLS2_EM_FFT7_u
1574116 1574250 pts/81   00:00:00 NSLS2_EM_FFT8_u
1574116 1574253 pts/81   00:00:00 NSLS2_EM_FFT9_u
1574116 1574256 pts/81   00:00:00 NSLS2_EM_FFT10_
1574116 1574259 pts/81   00:00:00 NSLS2_EM_FFT11_
1574116 1574360 pts/81   00:00:55 NSLS2_EM_FFT1_P
1574116 1574362 pts/81   00:00:56 NSLS2_EM_FFT2_P
1574116 1574364 pts/81   00:00:56 NSLS2_EM_FFT3_P
1574116 1574366 pts/81   00:00:57 NSLS2_EM_FFT4_P
1574116 1574368 pts/81   00:00:57 NSLS2_EM_FFT5_P
1574116 1574370 pts/81   00:00:58 NSLS2_EM_FFT6_P
1574116 1574372 pts/81   00:00:58 NSLS2_EM_FFT7_P
1574116 1574374 pts/81   00:00:57 NSLS2_EM_FFT8_P
1574116 1574376 pts/81   00:00:55 NSLS2_EM_FFT9_P
1574116 1574378 pts/81   00:00:53 NSLS2_EM_FFT10_
1574116 1574380 pts/81   00:00:50 NSLS2_EM_FFT11_
2189366 2189484 pts/55   00:00:00 FFT1_updateQueu
2189366 2189604 pts/55   00:00:00 FFT1_Plugin_1
2639210 2639311 pts/92   00:00:00 NSLS2_EM_FFT1_u
2639210 2639314 pts/92   00:00:00 NSLS2_EM_FFT2_u
2639210 2639317 pts/92   00:00:00 NSLS2_EM_FFT3_u
2639210 2639320 pts/92   00:00:00 NSLS2_EM_FFT4_u
2639210 2639323 pts/92   00:00:00 NSLS2_EM_FFT5_u
2639210 2639326 pts/92   00:00:00 NSLS2_EM_FFT6_u
2639210 2639329 pts/92   00:00:00 NSLS2_EM_FFT7_u
2639210 2639332 pts/92   00:00:00 NSLS2_EM_FFT8_u
2639210 2639335 pts/92   00:00:00 NSLS2_EM_FFT9_u
2639210 2639338 pts/92   00:00:00 NSLS2_EM_FFT10_
2639210 2639341 pts/92   00:00:00 NSLS2_EM_FFT11_
2639210 2639432 pts/92   00:01:35 NSLS2_EM_FFT1_P
2639210 2639434 pts/92   00:01:38 NSLS2_EM_FFT2_P
2639210 2639436 pts/92   00:01:42 NSLS2_EM_FFT3_P
2639210 2639438 pts/92   00:01:42 NSLS2_EM_FFT4_P
2639210 2639440 pts/92   00:01:43 NSLS2_EM_FFT5_P
2639210 2639442 pts/92   00:01:43 NSLS2_EM_FFT6_P
2639210 2639444 pts/92   00:01:42 NSLS2_EM_FFT7_P
2639210 2639446 pts/92   00:01:41 NSLS2_EM_FFT8_P
2639210 2639448 pts/92   00:01:37 NSLS2_EM_FFT9_P
2639210 2639450 pts/92   00:01:33 NSLS2_EM_FFT10_
2639210 2639452 pts/92   00:01:28 NSLS2_EM_FFT11_
2649780 2649898 pts/25   00:00:00 FFT1_updateQueu
2649780 2650015 pts/25   00:00:00 FFT1_Plugin_1
3809994 3810144 pts/61   00:00:00 FFT1_updateQueu
3809994 3810267 pts/61   00:00:00 FFT1_Plugin_1
Kiman
Sent: Saturday, September 27, 2025 12:22 PM
Hi Kiman, I just tested on my system, and I can’t reproduce the problem. This is not related to the issue of the plugin updates stopping, but I would suggest that you change the number of points from 1000 to 1024. I think the “beats”
Hi Kiman,
This is not related to the issue of the plugin updates stopping, but I would suggest that you change the number of points from 1000 to 1024.  I think the “beats” you see in frequency are artifacts of the fact that the number of points is not a power of 2.
This is what my Y position FFT looks like:
The first thing to do is open the detailed screens for that FFT plugin.  This is what I see with “More/FFT plugin”.  Note that Array rate=10 Hz, the execution time is 0.474 ms, and the array counter is incrementing at 10 Hz.  Are these values updating on your screen?
This is what I see when I press the More/NDPluginBase Full”  on the screen above:
The next thing to determine is whether Channel Access updates of the waveform record are being sent.  The way to test this is with camonitor.  This is what I see with camonitor on the X and Y positions, asking only for the first 2 points in the waveform.
(base) [epics@corvette ~]$ camonitor -#2 13IDA:QE1:FFT:PosX:FFTAbsValue
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.331851 2 0 1.15078
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.431627 2 0 1.15078
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.531824 2 0 1.15078
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.631831 2 0 0.822881
13IDA:QE1:FFT:PosX:FFTAbsValue 2025-09-27 10:56:29.731868 2 0 0.822881
^C
(base) [epics@corvette ~]$ camonitor -#2 13IDA:QE1:FFT:PosY:FFTAbsValue
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:34.831667 2 0 0.326255
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:34.931805 2 0 0.326255
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:35.031571 2 0 0.0809308
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:35.131777 2 0 0.0809308
13IDA:QE1:FFT:PosY:FFTAbsValue 2025-09-27 10:56:35.231808 2 0 0.0809308
They are both updating at 10 Hz, as expected.
What do you see when you run this camonitor command on your X and X FFT positions?
The next thing to do is use “ps” to list the threads with names that contain FFT.  This is what I see:
(base) [epics@corvette ~]$ ps -eL | grep FFT
1737089 1737178 pts/14   00:00:00 QE1_FFT1_update
1737089 1737181 pts/14   00:00:00 QE1_FFT2_update
1737089 1737184 pts/14   00:00:00 QE1_FFT3_update
1737089 1737187 pts/14   00:00:00 QE1_FFT4_update
1737089 1737190 pts/14   00:00:00 QE1_FFT5_update
1737089 1737193 pts/14   00:00:00 QE1_FFT6_update
1737089 1737196 pts/14   00:00:00 QE1_FFT7_update
1737089 1737199 pts/14   00:00:00 QE1_FFT8_update
1737089 1737202 pts/14   00:00:00 QE1_FFT9_update
1737089 1737205 pts/14   00:00:00 QE1_FFT10_updat
1737089 1737208 pts/14   00:00:00 QE1_FFT11_updat
1737089 1737301 pts/14   00:00:03 QE1_FFT1_Plugin
1737089 1737303 pts/14   00:00:04 QE1_FFT2_Plugin
1737089 1737305 pts/14   00:00:04 QE1_FFT3_Plugin
1737089 1737307 pts/14   00:00:04 QE1_FFT4_Plugin
1737089 1737309 pts/14   00:00:04 QE1_FFT5_Plugin
1737089 1737311 pts/14   00:00:04 QE1_FFT6_Plugin
1737089 1737313 pts/14   00:00:04 QE1_FFT7_Plugin
1737089 1737315 pts/14   00:00:04 QE1_FFT8_Plugin
1737089 1737317 pts/14   00:00:04 QE1_FFT9_Plugin
1737089 1737319 pts/14   00:00:04 QE1_FFT10_Plugi
1737089 1737321 pts/14   00:00:04 QE1_FFT11_Plugi
Note that there are 11 FFT threads with _update in the name and 11 with _Plugin in the name.  What do you see?  Are all the threads there?
Let me know the results of these tests on your system.
Sent: Friday, September 26, 2025 5:59 PM
To: [email protected]
Cc: Mark Rivers <[email protected]>
Subject: quadEM FFP plugin update issues
Hi Mark,
We are using a new NSLS2EM hardware setup with the quadEM IOC.
One of our IOCs has an issue where the FFT plugin stops updating shortly after the IOC is started.
Although the FFT plugin has stopped updating, the circular buffer index continues to update.
Time-domain display continues to work without any problems.
Do you have any suggestions or recommendations to help resolve this issue?
Is it possible to restart the FFT plugin without rebooting the IOC?
See plot the PosX FFT is still running but the PosY is stopped.
Kiman
RE: quadEM FFP plugin update issues Ha, Kiman via Tech-talk
RE: quadEM FFP plugin update issues Mark Rivers via Tech-talk
Prev: AreaDetector Collaboration Meeting - October 2nd Henrique F. Simoes via Tech-talk
Next: RE: quadEM FFP plugin update issues Ha, Kiman via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: quadEM FFP plugin update issues Mark Rivers via Tech-talk
