1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: EPICS CA and PVA across subnets
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Rivers, Mark L." <[email protected]>
Date: Tue, 30 Sep 2025 13:37:51 -0700
On 9/29/25 09:29, Johnson, Andrew N. via Tech-talk wrote:
I believe both CA and PVXS support using multicast for name searches
Correct.  I would encourage more use as I think IP multicast could be a good fit for a network with a complicated topology, but without trust boundaries necessitating a gateway.
(not sure about pvAccessCPP),
Nope.
but we don’t have much if any documentation for Base explaining how to configure CA to use that,
Nothing beyond this "test plan" I put together.
https ://wiki-ext.aps.anl.gov/epics/index.php?title=RSRV_Configuration_Test_Plan#Test_.236_IPv4_Multicast_for_search_and_beacons
There is actually not much configuration required.
The core choice is to include a site chosen 224.x.x.x address in the EPICS_*_ADDR_LIST.
could someone from Fermilab comment on that? I believe Fermi requested and possibly implemented this.
It would require configuring all the clients and servers, which the previous 2 suggestions don’t.
An item on my long TODO list is to request the assignment of (or simply choose) an IPv4 and/or IPv6 address to use by default.
EPICS CA and PVA across subnets Mark Rivers via Tech-talk
Re: EPICS CA and PVA across subnets Jure Varlec via Tech-talk
Re: EPICS CA and PVA across subnets Johnson, Andrew N. via Tech-talk
Prev: Re: Can pvlist show remote PVs behind a pvAccess gateway? Michael Davidsaver via Tech-talk
Next: Re: Fast stream-device IOC suddenly disconnects Zimoch, Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: EPICS CA and PVA across subnets Johnson, Andrew N. via Tech-talk
Next: Re: [EXTERNAL] Re: EPICS CA and PVA across subnets Kasemir, Kay via Tech-talk
