1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: [EXTERNAL] Re: EPICS CA and PVA across subnets
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Jure Varlec <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 29 Sep 2025 16:39:18 +0000
>  Even when you add the IOC to EPICS_PVA_ADDR_LIST, PVA doesn't seem to use TCP to do name searches.
Just like the EPICS_CA_ADDR_LIST, the EPICS_PVA_ADDR_LIST is used for UDP searches.
For TCP, set EPICS_PVA_NAME_SERVERS (just like EPICS_CA_NAME_SERVERS), typically like this to disable the UDP searches:
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_PVA_ADDR_LIST=""
EPICS_PVA_NAME_SERVERS=IP-of-PVA-server
You could list the IP addresses of several IOCs to search them all via TCP, but the list would get long.
The intended use it to list only one TCP address, a name server, so you get a reply from just one TCP connection.
Re: [EXTERNAL] Re: EPICS CA and PVA across subnets Jure Varlec via Tech-talk
EPICS CA and PVA across subnets Mark Rivers via Tech-talk
Prev: Re: EPICS CA and PVA across subnets Johnson, Andrew N. via Tech-talk
Next: RE: EPICS CA and PVA across subnets Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: EPICS CA and PVA across subnets Michael Davidsaver via Tech-talk
Next: Re: [EXTERNAL] Re: EPICS CA and PVA across subnets Jure Varlec via Tech-talk
