On 9/29/25 18:39, Kasemir, Kay wrote:
Even when you add the IOC to EPICS_PVA_ADDR_LIST, PVA doesn't
seem to use TCP to do name searches.
Just like the EPICS_CA_ADDR_LIST, the EPICS_PVA_ADDR_LIST is
used for UDP searches.
For TCP, set EPICS_PVA_NAME_SERVERS (just like
EPICS_CA_NAME_SERVERS), typically like this to disable the UDP
searches:
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_PVA_ADDR_LIST=""
EPICS_PVA_NAME_SERVERS=IP-of-PVA-server
That is a good point, I haven't used EPICS_CA_NAME_SERVERS for so
long that I have forgotten about it. It is very useful when you
are debugging an IOC over SSH where you can only forward a TCP
port. That works reliably.
However, it does not work with pvget or pvxget. I now found that
pvxget has a very nice -d option that prints a fair bit of info. I
can see that it connects to the TCP server, but can't resolve the
name. Based on what you wrote, this should work, so I guess it's
time to open an issue :)
Best,
Jure
- Re: [EXTERNAL] Re: EPICS CA and PVA across subnets Kasemir, Kay via Tech-talk
- EPICS CA and PVA across subnets Mark Rivers via Tech-talk
- Re: EPICS CA and PVA across subnets Jure Varlec via Tech-talk
RE: xspress3 internal triggering issue Keith Surrena via Tech-talk
<2025>
2026
<2025>
2026
