1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: xspress3 internal triggering issue
From: Keith Surrena via Tech-talk <[email protected]>
To: Matthew Newville <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Oct 2025 13:19:11 +0000
Thanks, Matt! I figured there was reasonable explanation, but didn’t know the specific hardware clock for the math.
Sent: Wednesday, October 8, 2025 8:49 AM
To: Keith Surrena <[email protected]>; [email protected]
Subject: Re: xspress3 internal triggering issue
Hi Keith,
The xspress3 (or, now “older xspress3”) will stop counting a single frame and overflow its scaler clock values at 53.68 seconds (2**32 ticks of its internal 80 MHz clock).   But you can do multiple (16348, typically, can be changed in the IOC startup) frames with dwell times up to that value.
I believe the newer xspress3 Mk2 has a 200 MHz clock, but I do not recall whether the limit of 4G bins has been increased.
--Matt
From: Tech-talk <[email protected]> on behalf of Keith Surrena via Tech-talk <[email protected]>
Date: Tuesday, October 7, 2025 at 2:10
 PM
To: [email protected] <[email protected]>
Subject: xspress3 internal triggering issue
I can no longer perform internally triggered data acquisitions with one of our 5 channel xspress3 units with dwell times that exceed 50 seconds. Last week I had set up a user that was doing 100 sec exposures with a weak source but over the weekend the IOC would stop the acquisition short, typically at around the 45 second mark, if not sooner. I have cycled all of the relevant hardware and controllers but the issue seems to persist. I can still seem to do long dwells with external triggers, but I appreciated the simplicity of utilizing internal triggers for the setup. Any thoughts?
Keith Surrena
Research Support Specialist
Cornell High Energy Synchrotron Source
xspress3 internal triggering issue Keith Surrena via Tech-talk
Re: xspress3 internal triggering issue Matthew Newville via Tech-talk
Prev: Re: Basic EPICS bootstrap (rant) Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Re: EPICS CA and PVA across subnets Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: xspress3 internal triggering issue Matthew Newville via Tech-talk
Next: Waveform VAL fields in newer versions of EPICS Baily, Scott A via Tech-talk
