1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Waveform VAL fields in newer versions of EPICS
From: "Baily, Scott A via Tech-talk" <[email protected]>
Date: Tue, 7 Oct 2025 23:19:22 +0000
In EPICS 3.14.12 IOCs running the command dba <waveformrecordname> returned a field address that was the same as the BPTR field of the waveform record.
In EPICS 3.15.9 and epics 7, this is no longer the case.  The dba command gets its information by calling dbNameToAddr as is proper for an SPC_DBADDR field, this should give the actual location of the VAL field contents.  In 3.14.12 this address is also stored in the BPTR field.  It appears that dbNameToAddr no longer results in paddr->pfield pointing to the contents of the VAL field.  Is this expected behavior? If so, how should one obtain the contents of SPC_DBADDR field? I assume this is available (for this specific case) if BPTR were directly referenced, but this doesn’t seem like the proper method.
Re: Waveform VAL fields in newer versions of EPICS Michael Davidsaver via Tech-talk
Prev: Re: Basic EPICS bootstrap (rant) Graeme Winter via Tech-talk
Next: Re: Basic EPICS bootstrap (rant) Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: xspress3 internal triggering issue Keith Surrena via Tech-talk
Next: Re: Waveform VAL fields in newer versions of EPICS Michael Davidsaver via Tech-talk
