Hi Graeme, I've put together a simple example
that might be helpful. Please check the following repository: You will still need to install the correct library packages. In this case, you can find them here: If the pre-built binaries do not support your "arm64" architecture, you can build them yourself using the instructions at: I hope this helps! Best, Han P.S.
You might also find a slightly older training resource on organizing
EPICS IOC environments here: https://jeonghanlee.github.io/epics-trainings/ On Tue, Oct 7, 2025 at 11:56 AM Graeme Winter via Tech-talk <[email protected]> wrote:
-- Jeong Han Lee, Dr.rer.nat. Staff Scientist and Engineer Lawrence Berkeley National Laboratory
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
