1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Basic EPICS bootstrap (rant)
From: Marco Filho via Tech-talk <[email protected]>
To: Graeme Winter <[email protected]>, Han Lee <[email protected]>
Date: Wed, 8 Oct 2025 06:16:02 +0000
Hi!
Might be a silly question, but expanding on this I wonder why is there no .deb package for EPICS? Is there any particular reason or did we just steer as a community towards other packaging methods?
Best regards,
Marco
From: Tech-talk <[email protected]> on behalf of Han Lee via Tech-talk <[email protected]>
Sent: Wednesday, October 8, 2025 07:43
Cc: [email protected] <[email protected]>
Hi Graeme,
Sorry for the duplicate email, I realized the links were broken.
I've put together a simple example that might be helpful. Please check the following repository:
https://github.com/jeonghanlee/EPICS-env-distribution
You will still need to install the correct library packages. In this case, you can find them here:
https://github.com/jeonghanlee/pkg_automation
If the pre-built binaries do not support your "arm64" architecture, you can build them yourself using the instructions at:
I hope this helps!
Best,
Han
P.S. You might also find a slightly older training resource on organizing EPICS IOC environments here:
https://jeonghanlee.github.io/epics-trainings/
On Tue, Oct 7, 2025 at 4:35 PM Han Lee <[email protected]> wrote:
Hi Graeme,
I hope this helps!
Best,
Han
P.S. You might also find a slightly older training resource on organizing EPICS IOC environments here: https://jeonghanlee.github.io/epics-trainings/
On Tue, Oct 7, 2025 at 11:56 AM Graeme Winter via Tech-talk <[email protected]> wrote:
Good afternoon
Working through
It really feels like this is something which could be made _much_ easier by writing a kind of bootstrap script but also by the configure process being able to pick up stuff from the environment rather than having to hard-code every location multiple times in every configuration file (where the defaults are of course where the author does _their_ epics development) - the need for them to all correctly cross-reference is also an irritation
Before I scrape another few mm off my already suffering sanity -
- _has_ anyone got a bootstrap script which will clone / install all the necessary / regular support modules
- am I holding it wrong / reading the wrong getting started guide
I note I can conda install epics-base but this _only_ gives epics base
That rant to one side, also, does anyone know how to address a missing symbol issue like
Undefined symbols for architecture arm64:
  "_pvar_func_vxi11RegisterCommands", referenced from:
      _cryo1_registerRecordDeviceDriver in cryo1_registerRecordDeviceDriver.o
ld: symbol(s) not found for architecture arm64
The symbol is indeed missing and would appear to be from asyn/vxi11/drvVxi11.c but does not appear to be built
This got me thinking I should re-do the NN steps to get back to here which then got me wondering about process itself…
Thanks Graeme
Jeong Han Lee, Dr.rer.nat.
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
Re: Basic EPICS bootstrap (rant) Simon Rose via Tech-talk
Re: Basic EPICS bootstrap (rant) Han Lee via Tech-talk
Basic EPICS bootstrap (rant) Graeme Winter via Tech-talk
Prev: Re: Basic EPICS bootstrap (rant) Han Lee via Tech-talk
Next: Re: Basic EPICS bootstrap (rant) Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
