1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Finding out what's commanding motor move?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 10 Oct 2025 14:40:36 -0500
On 10/10, Michael Davidsaver wrote:
> On 10/10/25 09:55, Mark Rivers via Tech-talk wrote:
> > I should add that casr will be most useful if the client that is doing the puts is continuously connected.  If the puts are being done, for example, with a caput command at some Linux shell, then the connections are very brief and casr is likely to miss it.
> One quick test would be setting DISP=1, which should block PUT operations to all record fields except DISP.
Ah, didn't think of that; that's a good idea too!
> And I will second Mark's mention of caPutLog.  imo. audit logging is necessary equipment for an operational control system.
Yes, I knew about that, but I didn't have it installed.  But if it had
been installed, then yes, that would have helped identify the problem as
well.  Re audit logging being necessary, you're probably right.  Thanks!
Lewis
Finding out what's commanding motor move? J. Lewis Muir via Tech-talk
RE: Finding out what's commanding motor move? Mark Rivers via Tech-talk
Re: Finding out what's commanding motor move? Michael Davidsaver via Tech-talk
Prev: Re: Finding out what's commanding motor move? J. Lewis Muir via Tech-talk
Next: RE: Basic EPICS bootstrap (rant) Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Finding out what's commanding motor move? Michael Davidsaver via Tech-talk
Next: Re: Finding out what's commanding motor move? J. Lewis Muir via Tech-talk
