1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: ADEiger complete script
From: Graeme Winter via Tech-talk <[email protected]>
Date: Mon, 27 Oct 2025 16:47:45 +0000
Hi Mark
Thank you
Yes, I had read the page you linked - I suspect that the second problem is a side-effect of the first i.e. if I did get the detector and IOC set up correctly then (as listed in the documentation) the files would be fetched automatically
I don’t currently have an operator interface running which I suspect is part of my problem - selecting between the options (EDM, MEDM are ~obsolete, but no successor has been anointed though there are numerous candidates?) also seems to be something of an unknown (having just read through a 12 year old slide deck) - though I am wary of making mention of this as it feels like opening a metaphorical can of worms
(Time passes)
OK, I have EDM built (which may not be the best solution, but it was one I was aware of) and now hit
No such font available: [-misc-liberation mono-medium-r-normal--0-90-75-75-m-0-*-*]
Last line processed: 71
Font init failed - abort
OK, I knew EDM + fonts + 2024 and later Linux wasn’t going to be a happy place
(More time passes)
OK, got MEDM built, now see what I missed!
Thank you! Now have files on disk
Now to tweak into a script…
All the best Graeme
On 27 Oct 2025, at 13:25, Mark Rivers <[email protected]> wrote:
Hi Graeme,
I think the easiest approach is to use the ADEiger OPI screen to show what PVs need to be configured.  Then you can do that with caput and look at the OPI screen to see the effect.  If you post a screen shot of the OPI screen I can see what might not be configured correctly.
Have you read the documentation here:
From: Tech-talk on behalf of Graeme Winter via Tech-talk
Sent: Monday, October 27, 2025 7:42 AM
To: [email protected]
Subject: ADEiger complete script
Good morning / afternoon
I have spent some time this morning trying to configure an Eiger “from scratch” using _only_ the ADEiger interface and caput
I have thus far failed!
If someone has an example script I would find that very helpful :-)
I am trying right now to set up collection of a series of frames from either an internal or external trigger - I understand the concepts and I am sure I could do it through the rest interface but I am keen to use the standard EPICS one if possible, using simply caput and scripting
Also: how to fetch the data from the file writer through the ADEiger interface would be handy too… I understand the stream interface but have never used the file writer one
I appreciate that this is probably all obvious to those who are in the know - I am not!
Thanks and all the best Graeme
Attachment: smime.p7s
Description: S/MIME cryptographic signature
ADEiger complete script Graeme Winter via Tech-talk
Re: ADEiger complete script Mark Rivers via Tech-talk
Prev: Re: ADEiger complete script Mark Rivers via Tech-talk
Next: areadetector PV for pilatus3 retrigger and count-rate correction Keith Surrena via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
