What is the best way (without having to write anything more than EPICS database code) to copy the value of a string PV (stringout) hosted in one IOC to a waveform PV (char type) hosted by another PC?
I'm having problems trying to set the output link to a waveform PV name.
Thank you,
Ray
Ray Gregory
DAS Software Group
NTD Division
NScD Directorate
Oak Ridge National Laboratory
Hi Mark, This is for our pilatus3 X 6M, so within this manual https: //media. dectris. com/user-manual-pilatus3-2020_GOKBotG. pdf. The specific commands are SetRetriggerMode and RateCorrLUTDir From: Mark Rivers <rivers@ cars. uchicago. edu> Sent:
Hi Mark,
https://media.dectris.com/user-manual-pilatus3-2020_GOKBotG.pdf. The specific commands are SetRetriggerMode and RateCorrLUTDir
Hi Keith,
Those commands are not supported in ADPilatus.
I just searched this Dectris camserver document for the string “retrigger” and it does exist.
https://media.dectris.com/User_Manual-PILATUS2-V1_4.pdf
Where did you find the documentation on the retrigger command?
I do see the documentation on the Tau command. ADPilatus currently only reads Tau, it does not allow setting it.
However, you can set it via the OPI screens as follows:
- In the screen pilatusDetector.adl open the Debugging/asyn record screen.
- Change the port on that screen to camserver (if that is what you called it in the startup script).
- Open the More/asynOctet interface I/O screen
- In the Output/ASCII screen type the camserver command. You will see the response in the Input/ASCII field.
I just tested this typing “Tau” to read the current setting, and I received the correct response.
On Behalf Of Keith Surrena via Tech-talk
Sent: Tuesday, October 28, 2025 9:51 AM
To:
[email protected]
Subject: areadetector PV for pilatus3 retrigger and count-rate correction
Are there PVs that exist for adjusting these parameters? Alternatively, since I know the specific camserver commands, is there a PV I can use to manually send strings to camserver? I
noticed that there is a StringToCamserver_RBV, which piques my interest.
Keith Surrena
Research Support Specialist
Cornell
High Energy Synchrotron Source
