1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Tech-talk Digest, Vol 19, Issue 478
From: Vijay Kumar Banerjee via Tech-talk <[email protected]>
To: "Hong, Ran" <[email protected]>
Date: Wed, 29 Oct 2025 15:03:25 -0700
Thanks for testing the patches!
On Wed, Oct 29, 2025, 2:55 PM Hong, Ran <[email protected]> wrote:
Hi Vijay,
I figured out how to down load the patches from techtalks, too. I figured out for the first patch I need a small tweak. Instead of modifying the patch file, I modified the source file to match what's in the patch.
Everything works now. I hope these patches can get into the main branch and branch 6 soon.
Cheers,
Ran Hong
Sent: Wednesday, October 29, 2025 2:25 PM
To: Hong, Ran <[email protected]>
Cc: [email protected] <[email protected]>
Hi Ran, I am attaching the three patches for libi2c for the main branch. To make it work with branch 3, you'll likely have to make minor edits on patch 0001. I have not had the time to make a patch version for branch 6 yet, but Nicholas
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Ran,
I am attaching the three patches for libi2c for the main branch. To make it work with branch 3, you'll likely have to make minor edits on patch 0001. I have not had the time to make a patch version for branch 6 yet, but Nicholas was able to get the libi2c working with a small modification in branch 6.
On Tue, Oct 28, 2025 at 2:36 PM Hong, Ran <[email protected]> wrote:
Hi Vijay,
I am having the same issue with i2c on branch 6. How can I get the patch set you used?
Thanks!
Ran Hong
From: Tech-talk <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Monday, October 27, 2025 7:42 AM
To: [email protected] <[email protected]>
Subject: Tech-talk Digest, Vol 19, Issue 478
Send Tech-talk mailing list submissions to
        [email protected]
To subscribe or unsubscribe via the World Wide Web, visit
        https://gcc02.safelinks.protection.outlook.com/?url="">
or, via email, send a message with subject or body 'help' to
[email protected]
You can reach the person managing the list at
        [email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. Re: Running EPICS on RTEMS/MVME3100 (Joel Sherrill)
   2. ADEiger complete script (Graeme Winter)
Message: 1
Date: Sun, 26 Oct 2025 20:13:25 +0100
To: Vijay Kumar Banerjee <[email protected]>
Cc: "Marks, Nicholas" <[email protected]>, Talk EPICS Tech
        <[email protected]>
Subject: Re: Running EPICS on RTEMS/MVME3100
Message-ID:
        <CAF9ehCXY0ppTycn8mKWLgZ9hcPS0c4hiAnBpG+QFFq+=[email protected]>
Content-Type: text/plain; charset="utf-8"
Sounds great. Ping me to review them.
--joel
On Sun, Oct 26, 2025, 4:07?PM Vijay Kumar Banerjee <[email protected]> wrote:
> Joel,
> mvme3100 has an issue with libi2c in both 6 and main. I have a patchset
> that Nicholas tested on hardware. I will open a ticket in RTEMS and an MR
> to fix it.
> On Sun, Oct 26, 2025, 1:40?AM Joel Sherrill <[email protected]>
> wrote:
>> Vijay.. Are these problems on the 6 and main branches for RTEMS.git and
>> libbsd? Are there patches we need to make sure get in 6 and main?
>> On Sun, Oct 26, 2025, 3:35?AM Vijay Kumar Banerjee via Tech-talk <
>>> Hi Andrew,
>>> That setting needs to be part of the application that needs libi2c
>>> initialized. So, it might be possible to add it somewhere in the IOC
>>> instead of rtems_config.
>>> I am not sure about the status of mvme3100 with libbsd. I remember we
>>> were able to run nfsv4 on libbsd with one of the boards, but I am not sure
>>> if we needed any other configurations. I am not aware of any issues other
>>> than the i2c problem we discussed in this thread.
>>> On Sat, Oct 25, 2025, 5:02?PM Johnson, Andrew N. <[email protected]> wrote:
>>>> Hi Vijay,
>>>> Thanks for responding! Could that setting be part of the BSP, maybe
>>>> conditionally on some other setting that all our boards might enable?
>>>> Many different boards will use the EPICS rtems_confic.c file and they
>>>> won?t all need that setting (some of them might not have an i2c bus at
>>>> all).
>>>> What else do you think would be needed for the mvme3100 BSP to be
>>>> buildable with the netbsd network stack instead of the legacy one? That
>>>> ?s a configuration that we?re going to want to use...
>>>> - Andrew
>>>> Complexity comes for free, Simplicity you have to work for.
>>>> On 10/25/25, 6:02?PM, "Tech-talk" <[email protected]>
>>>> wrote:
>>>> Awesome!
>>>> I'm glad it worked. I remember having to edit the rtems_confic.c to
>>>> make it work.
>>>> RTEMS defines a macro RTEMS_BSP. Is it possible to add
>>>> #if RTEMS_BSP == mvme3100
>>>> In rtems_config.c, and add the configure option under it, since I2C is
>>>> always required for EPICS on that BSP? Would that be an okay change for
>>>> EPICS base?
>>>> On Sat, Oct 25, 2025 at 8:45?AM Marks, Nicholas <[email protected]> wrote:
>>>> Vijay,
>>>> I realized my "hello.exe" test there was a typo in the #define. It
>>>> works now! For EPICS I tried adding it in a few different places that
>>>> didn't work before I added to modules/libcom/RTEMS/posix/rtems_config.c in
>>>> EPICS base which worked. Maybe there is a better way or a way to add it to
>>>> the IOC itself rather than modifying EPICS base? I need to sort out some
>>>> NFS issues first before the IOC will boot, but my initial problems are
>>>> solved.
>>>> Thank you!
>>>> Nick
>>>> *From:* Vijay Kumar Banerjee <[email protected]>
>>>> *Sent:* Friday, October 24, 2025 10:24 PM
>>>> *To:* Marks, Nicholas <[email protected]>
>>>> *Cc:* [email protected] <[email protected]>
>>>> *Subject:* Re: Running EPICS on RTEMS/MVME3100
>>>> Hi Nicholas,
>>>> Have you tried adding the macro
>>>> #define CONFIGURE_APPLICATION_NEEDS_LIBI2C_DRIVER
>>>> On Fri, Oct 24, 2025, 7:30?PM Marks, Nicholas <[email protected]> wrote:
>>>> Hi Vijay,
>>>> Thanks, I'm trying with the 6 branches for now. Your patches *almost* applied
>>>> without a hitch, however the 0001 patch failed to apply automatically for
>>>> the rtems_i2c_init function. I believe I made the edits manually so this
>>>> should be correct?:
>>>> /* Note that 'arg' is always passed in as NULL */
>>>> rtems_status_code
>>>> rtems_i2c_init (rtems_device_major_number major,
>>>> rtems_device_minor_number minor,
>>>>           void *arg)
>>>>   /* No busses or drivers can be registered at this point;
>>>>    * avoid the macro aborting with an error
>>>>   DECL_CHECKED_DRV (drv, busno, minor)
>>>>     rtems_mutex_init(&libmutex, "LIBI2C");
>>>>     rtems_libi2c_is_initialized     = true;
>>>>     rtems_libi2c_major = major;
>>>>     return 0;
>>>> The other patches appear to have applied without issue. Running some
>>>> examples, I get different errors now. Running the hello.exe example, I get
>>>> a "LIBI2C NOT INITIALIZED" message (see below). I've tried some EPICS
>>>> applications too which have similar results. My guess is the EPICS network
>>>> initialization is failing since the I2C driver isn't initialized and the
>>>> network chip on the MVME communicates via I2C? Anyway, I appreciate the
>>>> help and if you have any additional suggestions or patches you'd like me to
>>>> test I'm all ears. Thanks!
>>>> Exit from bspstart
>>>> Tundra Tsi148 PCI-VME bridge detected at 0x80100000, IRQ 0
>>>> Tsi148 Outbound Ports:
>>>> Port  VME-Addr   Size       PCI-Adrs   Mode:
>>>> 0:    0x20000000 0x0e000000 0xc0000000 A32, SUP, D32, SCT
>>>> 1:    0x00000000 0x00ff0000 0xcf000000 A24, SUP, D32, SCT
>>>> 2:    0x00000000 0x00010000 0xcfff0000 A16, SUP, D32, SCT
>>>> 7:    0x00000000 0x01000000 0xce000000 CSR, SUP, D32, SCT
>>>> Tsi148 Inbound Ports:
>>>> 0:    0xc0000000 0x20000000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT,
>>>> BLT
>>>> vmeTsi148 IRQ manager: looking for registers on VME...
>>>> Trying to find CSR on VME...
>>>> vmeTsi148 - IRQ manager using VME CSR to flush FIFO
>>>> Registering /dev/console as minor 0 (==/dev/ttyS0)
>>>> Hello World
>>>> [ RTEMS shutdown ]
>>>> RTEMS version: 6.0.0.36a3845d9cf896bb14ad9a9534b8f6acacba39b4-modified
>>>> RTEMS tools: 13.3.0 20240521 (RTEMS 6, RSB
>>>> 9a03d058f3de052ac50e4ea29f78350ea2ecc7ab, Newlib 1b3dcfd)
>>>> executing thread ID: 0x0a010001
>>>> *Sent:* Friday, October 24, 2025 2:19 PM
>>>> *Cc:* Heinz Junkes <[email protected]>; [email protected] <
>>>> [email protected]>
>>>> You don't often get email from [email protected]. Learn why this is
>>>> important
>>>> <https://gcc02.safelinks.protection.outlook.com/?url="">>
>>>> The patch should apply cleanly to the main branch. I have not tried
>>>> applying on branch 6, but I would think that it should apply as the code
>>>> related to patch has not changed during this time.
>>>> rtems-net-legacy is required if your application needs networking.
>>>> rtems-net-legacy build on main for powerpc is currently broken due to a
>>>> recent deprecation of "set_vector()" directive. I am working on a fix for
>>>> this, but it might be next week because I generally get to work on this
>>>> during weekends only :)
>>>> Meanwhile, you can try the patches with RTEMS 6. If it doesn't apply
>>>> cleanly, I am happy to modify the patch accordingly
>>>> Best,
>>>> Vijay
>>>> On Fri, Oct 24, 2025 at 11:17?AM Marks, Nicholas <
[email protected]>
>>>> wrote:
>>>> Thank you all for the suggestions.
>>>> Vijay: I am working on trying your patches today. Is this intended to
>>>> be applied to the version 6 branch, or to the main branch? If it is for the
>>>> main branch, is the rtems-net-legacy package still required for using RTEMS
>>>> on the MVME3100 with EPICS? Building rtems-net-legacy with waf on RTEMS 6.1
>>>> worked fine but not with RTEMS from the main branch...but perhaps this is
>>>> expected.
>>>> - Nick
>>>> *Sent:* Friday, October 24, 2025 1:16 AM
>>>> *To:* Heinz Junkes <[email protected]>
>>>> *Cc:* Marks, Nicholas <[email protected]>; [email protected] <
>>>> [email protected]>
>>>> important
>>>> Hello Nicholas, and others
>>>> I was able to get the mvme3100 running with EPICS IOC on RTEMS 6
>>>> some time ago. I have a patchset to get the RTEMS libi2c properly
>>>> initialized with mvme3100
>>>> Somehow, these patches fell through the cracks and didn't make it to
>>>> RTEMS upstream.
>>>> I'm attaching the patches here. Could you please test them? I do not
>>>> have access to a hardware to be able to test them. I have only checked that
>>>> they apply cleanly on the current master. Please let me know if there are
>>>> any issues with the patches.
>>>> Heinz, with these patches, you would not need to directly call
>>>> _IO_All_drivers_initialized. The EPICS RTEMS application needs to have the
>>>> following configure option added to the application code
>>>> If these patches fix the mvme3100 I2C issue, I am happy to open a merge request at upstream RTEMS and try to get it merged.
>>>> Thanks,
>>>> Vijay
>>>> On Thu, Oct 23, 2025 at 7:41?PM Heinz Junkes via Tech-talk <
>>>> Hello Marks,
>>>> We have been running the MVME3100 with the MVME3100 for quite some time
>>>> now. But still with RTEMS5.
>>>> I applied the following kernel patch at the time, which solved a
>>>> problem with the i2c driver.
>>>> rtems@rtems-dev:~/MVME3100$ cat kernel.patch
>>>> diff --git a/bsps/powerpc/mvme3100/start/bspstart.c
>>>> b/bsps/powerpc/mvme3100/start/bspstart.c
>>>> index 0ec215e33b..96d6e2f9cd 100644
>>>> --- a/bsps/powerpc/mvme3100/start/bspstart.c
>>>> +++ b/bsps/powerpc/mvme3100/start/bspstart.c
>>>> @@ -52,6 +52,8 @@
>>>>  extern unsigned long __rtems_end[];
>>>>  extern unsigned      ppc_exc_lock_std, ppc_exc_gpr3_std;
>>>> +extern bool _IO_All_drivers_initialized;
>>>>   * Copy Additional boot param passed by boot loader
>>>> @@ -419,7 +421,14 @@ void bsp_start( void )
>>>>  static void mvme3100_i2c_initialize(void)
>>>> +  printk("-------- call BSP_i2c_initialize() with
>>>> _IO_All_drivers_initialized = true\n");
>>>> +   * we need the drivers registered as they appear, due to get
>>>> +   * the i2c devices ready
>>>> +  _IO_All_drivers_initialized = true;
>>>>    BSP_i2c_initialize();
>>>> +  _IO_All_drivers_initialized = false;
>>>>  RTEMS_SYSINIT_ITEM(
>>>> diff --git a/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
>>>> b/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
>>>> index 48a61b9329..842cb92d67 100644
>>>> --- a/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
>>>> +++ b/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
>>>> @@ -43,8 +43,8 @@ librtemsbsp_a_SOURCES +=
>>>> ../../../../../../bsps/powerpc/shared/start/bspgetworka
>>>> ../../../../../../bsps/powerpc/shared/start/zerobss.c
>>>> ../../../../../../bsps/powerpc/shared/start/sbrk.c
>>>> ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>>> -librtemsbsp_a_SOURCES +=
>>>> ../../../../../../bsps/shared/start/bspfatal-default.c
>>>> ../../../../../../bsps/shared/start/bspreset-empty.c
>>>> +librtemsbsp_a_SOURCES +=
>>>> ../../../../../../bsps/powerpc/mvme3100/start/bspclean.c
>>>>  # tod
>>>> ../../../../../../bsps/shared/dev/rtc/rtc-support.c
>>>> ../../../../../../bsps/powerpc/mvme3100/rtc/todcfg.c
>>>> To what extent
>>>> has this now been incorporated into the official release?
>>>> I'll be happy to look into this when I get the chance.
>>>> HTH,
>>>> Heinz
>>>> Fritz-Haber-Institut  | Phone: (+49 30) 8413-4270
>>>> Heinz Junkes          | VC: https://gcc02.safelinks.protection.outlook.com/?url="">
>>>> Faradayweg 4-6
>>>>       | Visitors:
Hittorfstrasse 29
>>>> <https://gcc02.safelinks.protection.outlook.com/?url="">> (Bld
>>>> S (Slough House) )
>>>> D - 14195 Berlin
>>>> ?Sorry I?m a bit late, had a terrible time?
>>>> All sort of things cropping up at the last moment. Uh, how are we for
>>>> time??
>>>> ?Zarquon's address to Milliways
>>>> > On 24. Oct 2025, at 00:12, Marks, Nicholas via Tech-talk <
>>>> > Hello,
>>>> > Has anyone succeeded recently in getting an IOC to run on RTEMS on
>>>> the MVME3100?  I've been trying but haven't had much luck. I have built
>>>> RTEMS 6.1 using the RTEMS source builder with the MVME3100 BSP and I have
>>>> successfully run several of the provided test applications (
https://gcc02.safelinks.protection.outlook.com/?url="">>).
>>>> I also built EPICS base 7.0.9 for RTEMS-mvme3100, however any EPICS
>>>> applications I create do not work. I believe the failure is during BSP
>>>> initialization before the IOC code even enters the picture since if I
>>>> remove everything from the IOC's main function except a single printf, the
>>>> same crash is present, and no print. I've pasted the VME console output
>>>> below this message.
>>>> > Note that the console hangs for several minutes after this line
>>>> "ds1375_probe (open): No such file or directory" before printing the
>>>> > ""%s" is not a valid command pathname." message, which comes from
>>>> either
>>>> > base/modules/libcom/RTEMS/score/rtems_init.c
>>>> > or
>>>> > base/modules/libcom/RTEMS/posix/rtems_init.c
>>>> > When running the RTEMS test programs that work, the "ds1375_probe..."
>>>> line is not present.
>>>> > Any suggestions would be appreciated. Thank you.
>>>> > MVME3100> go -a4000000
>>>> > Welcome to rtems-6.1.0 (PowerPC/Generic (no FPU)/mvme3100)
>>>> > BSP: mvme3100, CVS Release ($Name$)
>>>> > CPU 0x8020 - rev 0x20
>>>> > Additionnal boot options are H
>>>> > Initial system stack at 465df0
>>>> > Going to start PCI buses scanning and initialization
>>>> > Board Type: MVME3100-1263 (S/N EFDD3B6)
>>>> > External (=PCI Bus) Clock Freq   :   66666666 Hz
>>>> > Core Complex Bus (CCB) Clock Freq:  333333330 Hz
>>>> > CPU Clock Freq:                     166666665 Hz
>>>> > Ethernet 0                  EC:9E:CD:19:41:FF
>>>> > Ethernet 1                  EC:9E:CD:19:42:00
>>>> > Ethernet 2                  EC:9E:CD:19:42:01
>>>> > Number of PCI buses found is : 3
>>>> > BUS:SLOT:FUN  VENDOR-DEV_ID: COMMAND STATUS BASE_ADDR0 BASE_ADDR1
>>>> IRQ_PIN ->
>>>> >   0:0x00:0    0x1057-0x0008:  0x0006 0x20b0 0x80000000 0x00000000
>>>>    0 ->
>>>> >   0:0x11:0    0x10e3-0x0148:  0x0146 0x02b0 0x80100004 0x00000000
>>>>    1 ->
>>>> >   0:0x12:0    0x10b5-0x6520:  0x0147 0x02b0 0x00000000 0x00000000
>>>>    0 ->
>>>> >   0:0x13:0    0x10b5-0x6520:  0x0147 0x02b0 0x00000000 0x00000000
>>>>    0 ->
>>>> >   0:0x14:0    0x1095-0x3124:  0x01c7 0x02b0 0x80400004 0x00000000
>>>>    1 ->   2 (=0x0
>>>> >   2:0x00:0    0x1033-0x0035:  0x0146 0x0210 0x80300000 0x00000000
>>>>    1 ->   4 (=0x0
>>>> >   2:0x00:1    0x1033-0x0035:  0x0146 0x0210 0x80301000 0x00000000
>>>>    2 ->   5 (=0x0
>>>> > Memory:                             536870912 bytes
>>>> > Cleared PCI errors: pci_stat was 0x20b0
>>>> > OpenPIC Version 1.2 (1 CPUs and 56 IRQ sources) at 0x3775135744
>>>> > OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0
>>>> > OpenPIC timer frequency is 41666666 Hz
>>>> > MSR is 0x00001000, TCR 0x04000000
>>>> > Exit from bspstart
>>>> BLT
>>>> > libi2c: Library not initialized
>>>> > Registering mpc8540 i2c bus driver :No such file or directory
>>>> > *** FATAL ***
>>>> > fatal source: 11 (RTEMS_FATAL_SOURCE_PANIC)
>>>> > fatal code: 3444772 (0x00349024)
>>>> > RTEMS version: 6.1.0.not-released
>>>> > RTEMS tools: 13.3.0 20240521 (RTEMS 6, RSB no-repo, Newlib 1b3dcfd)
>>>> > executing thread ID: 0x0b010001
>>>> > Copyright(C)2008-2013,Emerson Network Power-Embedded Computing,Inc.
>>>> > All Rights Reserved
>>>> > Copyright Motorola Inc. 1999-2007, All Rights Reserved
>>>> > MOTLoad RTOS Version 2.0,  PAL Version 1.2 RM04
>>>> > Wed Nov  6 17:17:43 MST 2013
>>>> > MPU-Type             =MPC8540
>>>> > MPU-Int Clock Speed  =833MHz
>>>> > MPU-CCB Clock Speed  =333MHz
>>>> > MPU-DDR Clock Speed  =166MHz
>>>> > MPU-PCI Clock Speed  =66MHz, PCI, 64-bit
>>>> > MPU-Int Cache(L2) Enabled, 256KB, L2CTL =A8000300
>>>> > Reset/Boot Vector    =Flash0
>>>> > Local Memory Found   =20000000 (&536870912)
>>>> > User Download Buffer =0159D000:0179CFFF
>>>> > MVME3100>
URL: <
Message: 2
Date: Mon, 27 Oct 2025 12:42:11 +0000
[email protected]>
Subject: ADEiger complete script
Message-ID: <[email protected]" target="_blank" rel="noreferrer">[email protected]>
Good morning / afternoon
I have spent some time this morning trying to configure an Eiger ?from scratch? using _only_ the ADEiger interface and caput
I have thus far failed!
If someone has an example script I would find that very helpful :-)
I am trying right now to set up collection of a series of frames from either an internal or external trigger - I understand the concepts and I am sure I could do it through the rest interface but I am keen to use the standard EPICS one if possible, using simply caput and scripting
Also: how to fetch the data from the file writer through the ADEiger interface would be handy too? I understand the stream interface but have never used the file writer one
I appreciate that this is probably all obvious to those who are in the know - I am not!
Thanks and all the best Graeme
Type: application/pkcs7-signature
Desc: not available
URL: <https://gcc02.safelinks.protection.outlook.com/?url="">>
Subject: Digest Footer
[email protected]
End of Tech-talk Digest, Vol 19, Issue 478
Re: Tech-talk Digest, Vol 19, Issue 478 Hong, Ran via Tech-talk
Re: Tech-talk Digest, Vol 19, Issue 478 Vijay Kumar Banerjee via Tech-talk
Prev: Re: Tech-talk Digest, Vol 19, Issue 478 Hong, Ran via Tech-talk
Next: RE: Ubuntu 25.10 EPICS modules will not compile Graeme Elliner via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: PVAccess UDP/TCP connections failing - no more data in UDP packet Kacper Kłys DMCS via Tech-talk
