1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Ubuntu 25.10 EPICS modules will not compile
To: Graeme Elliner <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 30 Oct 2025 08:42:25 +0000
Hi Graeme –
Another option (which we are using for the time being) is to simply specify that you want to use an older c/c++ standard. You can add something like
USR_CFLAGS += -std=c17
USR_CXXFLAGS += -std=c++17
To your CONFIG_SITE.local file in EPICS base, or some variant to specify that you are using an older version of the standard.
Cheers,
Simon Rose
Software Engineer
European Spallation Source (ERIC)
From: Tech-talk <[email protected]> on behalf of Graeme Elliner via Tech-talk <[email protected]>
Reply to: Graeme Elliner <[email protected]>
Date: Thursday, 30 October 2025 at 09:06
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Subject: RE: Ubuntu 25.10 EPICS modules will not compile
Thanks Mark
I’ll pull these down and have a try.
I did try using GCC14 and I still had a problem, but perhaps I didn’t clean the build and reinstall the files properly
Best Regards,
Graeme Elliner
XDS Oxford Limited
Sent: 29 October 2025 16:22
To: [email protected]; Graeme Elliner <[email protected]>
[EXTERNAL]
This is because GCC 15 is stricter.  There are already pull requests to fix this in asyn and calc:
It looks like similar changes will be needed in sscan, StreamDevice, and sequencer.
Sent: Wednesday, October 29, 2025 10:24 AM
To: [email protected] <[email protected]>
Subject: Ubuntu 25.10 EPICS modules will not compile
Hi
I’m trying to set up a new EPICS PC running the latest Ubuntu OS, I’ve downloaded the latest versions of epics-base and the basic modules (asyn, calc, sscan, StreamDevice, sequencer) from github
Epics base compiles fine, however I get pretty much the same error from all the modules ‘long int (*)(void)’ from incompatible pointer type [Wincompatible-pointer-types]
Here is my set up
OS = Ubuntu 25.10
Gcc= 15.2.0
$EPICS_HOST_ARCH = linux-x86_64
$EPICS_BASE=/opt/epics/base
$EPICS_SUPPORT = /opt/epics/modules
Best Regards,
Graeme Elliner
Senior Control & Electrical Engineer
XDS Oxford Limited
Tel: 01865 320311 Direct Dial
Tel: 01865 320300 Switchboard
A green and blue logo
Description automatically generated
(formerly trading as FMB Oxford)
Visit us at:
www.xds-oxford.com
www.linkedin.com/company/xds-oxford
www.facebook.com/XDSOxford
www.x.com/XDS_Oxford
 P Before you print think about the ENVIRONMENT
XDS Oxford Limited is registered in England and Wales, Company number 04138193.
Registered office address: Unit 1 Ferry Mills, Osney Mead, Oxford, Oxfordshire, United Kingdom, OX2 0ES.
This e-mail message may contain confidential information and is intended for the addressee only. If you are not the intended recipient, please notify the sender by return e-mail and delete this message immediately.
Reproduction, dissemination or distribution of this message is prohibited unless authorised by the sender. The views expressed by the sender are not necessarily those of XDS Oxford Limited.
This e-mail has passed through Microsoft's Exchange Online Protection services. XDS Oxford Limited accepts no responsibility for any viruses not revealed.
Ubuntu 25.10 EPICS modules will not compile Graeme Elliner via Tech-talk
Re: Ubuntu 25.10 EPICS modules will not compile Mark Rivers via Tech-talk
RE: Ubuntu 25.10 EPICS modules will not compile Graeme Elliner via Tech-talk
Prev: RE: Ubuntu 25.10 EPICS modules will not compile Graeme Elliner via Tech-talk
Next: Re: Indicating IOC Console Message Activity (Sintschuk, Michael) NADOT Victor via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Ubuntu 25.10 EPICS modules will not compile Ralph Lange via Tech-talk
