This Message Is From an External Sender
This message came from outside your organization.
Yes, I think this is using this binary protocol:
https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*www.zaber.com/w/Manuals/Binary_Protocol_Manual__;!!G_uCfscf7eWS!ZCj-YSJc2mHFFxr1Iwa7LWm_qKkyXfIkKBN_fmWYktGO75anQy1YUUzusFvvBx7lXnqP0IEaBO6sFzCWZ6wHKhr2H4vr$__;Lw!!P4SdNyxKAPE!CKbzhsIt7VOEybic3fiZIhT6sg1wPbIIBxK--vWFC4OdDIvNsAUCdotT9xvD9ZE0MrDbFlav0XWcsNsHF14H7-I$
Best, Laurenz
On 06.11.2025 10:48, Torsten Bögershausen wrote:
> Thanks.
> Not having digged into StreamDevice for a long time:
> It looks as if your database is using a binary communication ?!
> But yes, it should be "easy" to write a proper motor driver.
> Or use the soft motor.
> /Torsten
> On 2025-11-06 10:09, Laurenz Rettig wrote:
>> Hi Torsten,
>> I added the files here:
https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*github.com/rettigl/epics_zaber_mirror__;!!G_uCfscf7eWS!ZCj-YSJc2mHFFxr1Iwa7LWm_qKkyXfIkKBN_fmWYktGO75anQy1YUUzusFvvBx7lXnqP0IEaBO6sFzCWZ6wHKu271Cvb$__;Lw!!P4SdNyxKAPE!CKbzhsIt7VOEybic3fiZIhT6sg1wPbIIBxK--vWFC4OdDIvNsAUCdotT9xvD9ZE0MrDbFlav0XWcsNsH6t4ciII$
>> Best, Laurenz
>> On 06.11.2025 09:57, Torsten Bögershausen wrote:
>>> Hej Laurenz,
>>> Is there a public Gir repo for your streamdevice files ?
>>> As Matt pointed out, the streamdevice files may be a starting
>>> point to develop a model 3 motor driver.
>>> Which does support motorRecord and does support other records.
>>> Advanced note:
>>> It is possible to put a "softMotor" on top of EPICS records:
>>> You need to have input records for:
>>> a) The actual position of the motor
>>> b) Is the motor "done" (the opposite of busy)
>>> c) You need an output record where the softMotor
>>> can write the new target position, where the motor should move to.
>>> (End of advanced comments)
>>> /Torsten
>>> On 2025-11-05 09:57, Laurenz Rettig via Tech-talk wrote:
>>>> We are using a stepper motor controlled mirror holder from Zaber,
>>>> which we control via stream device. No proper Epics motor support,
>>>> though. I could share the support files, if of interest.
>>>> Best, Laurenz
>>>> On 05.11.2025 09:24, Ralph Lange via Tech-talk wrote:
>>>>> Of ITER's many Diagnostics systems, one plans to use a Zaber
>>>>> linear stage.
>>>>> Is anyone using Zaber devices?
>>>>> Zaber has an open-source high-level library (Zaber Motion Library)
>>>>> written in Go with wrappers for a bunch of languages, on top of an
>>>>> ASCII-over-TCP protocol. Any experiences with that?
>>>>> Thanks for any leads...
>>>>> ~Ralph
Dr. Laurenz Rettig
[email protected]
Emmy Noether Research Group Dynamics of Correlated Materials
Fritz Haber Institute of the Max Planck Society
Department of Physical Chemistry
Faradayweg 4-6 Tel: +49 30 8413 5225
14195 Berlin, Germany Fax: +49 30 8413-5387
