1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Anyone using Zaber motion controllers?
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: "Wlodek, Jakub" <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>, Ralph Lange <[email protected]>, Laurenz Rettig <[email protected]>
Date: Thu, 6 Nov 2025 14:24:36 +0000
Excellent!
I see they do include a compiled library that you need to link to. Although they also have the source code available here: https://gitlab.com/ZaberTech/zaber-motion-lib
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Thursday, November 6, 2025 8:03 AM
To: Torsten Bögershausen <[email protected]>; [email protected]; Ralph Lange <[email protected]>; Laurenz Rettig <[email protected]>
Subject: [EXTERNAL] Re: Anyone using Zaber motion controllers?
Hi all, One of our beamlines recently looked into purchasing zaber stages and I found that the vendor themselves actually provide a EPICS motor record driver on their github: https: //github. com/zabertech/motorZaberMotion I have not had a chance
Hi all,
One of our beamlines recently looked into purchasing zaber stages and I found that the vendor themselves actually provide a EPICS motor record driver on their github: https://github.com/zabertech/motorZaberMotion
I have not had a chance to test it yet since the hardware has not arrived, but presumably that may be an option.
Jakub Wlodek
Technology Engineer
Data Acquisition and Detectors
National Synchrotron Light Source II
Office: 631.344.7599
[email protected]
Twitter | Facebook | Instagram | LinkedIn
From: Tech-talk <[email protected]> on behalf of Laurenz Rettig via Tech-talk <[email protected]>
Sent: Thursday, November 6, 2025 4:57 AM
To: Torsten Bögershausen <[email protected]>; [email protected] <[email protected]>; Ralph Lange <[email protected]>
Subject: Re: Anyone using Zaber motion controllers?
Yes, I think this is using this binary protocol:
https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*www.zaber.com/w/Manuals/Binary_Protocol_Manual__;!!G_uCfscf7eWS!ZCj-YSJc2mHFFxr1Iwa7LWm_qKkyXfIkKBN_fmWYktGO75anQy1YUUzusFvvBx7lXnqP0IEaBO6sFzCWZ6wHKhr2H4vr$__;Lw!!P4SdNyxKAPE!CKbzhsIt7VOEybic3fiZIhT6sg1wPbIIBxK--vWFC4OdDIvNsAUCdotT9xvD9ZE0MrDbFlav0XWcsNsHF14H7-I$
Best, Laurenz
On 06.11.2025 10:48, Torsten Bögershausen wrote:
> Thanks.
> Not having digged into StreamDevice for a long time:
> It looks as if your database is using a binary communication ?!
> But yes, it should be "easy" to write a proper motor driver.
> Or use the soft motor.
> /Torsten
> On 2025-11-06 10:09, Laurenz Rettig wrote:
>> Hi Torsten,
>> I added the files here: https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*github.com/rettigl/epics_zaber_mirror__;!!G_uCfscf7eWS!ZCj-YSJc2mHFFxr1Iwa7LWm_qKkyXfIkKBN_fmWYktGO75anQy1YUUzusFvvBx7lXnqP0IEaBO6sFzCWZ6wHKu271Cvb$__;Lw!!P4SdNyxKAPE!CKbzhsIt7VOEybic3fiZIhT6sg1wPbIIBxK--vWFC4OdDIvNsAUCdotT9xvD9ZE0MrDbFlav0XWcsNsH6t4ciII$
>> Best, Laurenz
>> On 06.11.2025 09:57, Torsten Bögershausen wrote:
>>> Hej Laurenz,
>>> Is there a public Gir repo for your streamdevice files ?
>>> As Matt pointed out, the streamdevice files may be a starting
>>> point to develop a model 3 motor driver.
>>> Which does support motorRecord and does support other records.
>>> Advanced note:
>>> It is possible to put a "softMotor" on top of EPICS records:
>>> You need to have input records for:
>>> a) The actual position of the motor
>>> b) Is the motor "done" (the opposite of busy)
>>> c) You need an output record where the softMotor
>>> can write the new target position, where the motor should move to.
>>> (End of advanced comments)
>>> /Torsten
>>> On 2025-11-05 09:57, Laurenz Rettig via Tech-talk wrote:
>>>> We are using a stepper motor controlled mirror holder from Zaber,
>>>> which we control via stream device. No proper Epics motor support,
>>>> though. I could share the support files, if of interest.
>>>> Best, Laurenz
>>>> On 05.11.2025 09:24, Ralph Lange via Tech-talk wrote:
>>>>> Of ITER's many Diagnostics systems, one plans to use a Zaber
>>>>> linear stage.
>>>>> Is anyone using Zaber devices?
>>>>> Zaber has an open-source high-level library (Zaber Motion Library)
>>>>> written in Go with wrappers for a bunch of languages, on top of an
>>>>> ASCII-over-TCP protocol. Any experiences with that?
>>>>> Thanks for any leads...
>>>>> ~Ralph
Dr. Laurenz Rettig                  [email protected]
Emmy Noether Research Group Dynamics of Correlated Materials
Fritz Haber Institute of the Max Planck Society
Department of Physical Chemistry
Faradayweg 4-6                         Tel: +49 30 8413 5225
14195 Berlin, Germany                  Fax: +49 30 8413-5387
Re: Anyone using Zaber motion controllers? Ralph Lange via Tech-talk
Re: Anyone using Zaber motion controllers? Laurenz Rettig via Tech-talk
Re: Anyone using Zaber motion controllers? Torsten Bögershausen via Tech-talk
Re: Anyone using Zaber motion controllers? Wlodek, Jakub via Tech-talk
Prev: Re: Anyone using Zaber motion controllers? Wlodek, Jakub via Tech-talk
Next: Controls Software Group Leader Plötzeneder Birgit via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Anyone using Zaber motion controllers? Ralph Lange via Tech-talk
