1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: pvxs Access/list problem
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Heinz Junkes (FHI)" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 10 Nov 2025 08:17:00 -0800
On 11/10/25 1:34 AM, Heinz Junkes (FHI) via Tech-talk wrote:
Unfortunately, reading the PVs doesn't work either:
(base) hactar:~ junkes$ env |grep EPICS_PVA
EPICS_PVA_ADDR_LIST=141.14.128.12
EPICS_PVA_AUTO_ADDR_LIST=NO
(base) hactar:~ junkes$ pvget rtems:aiExample
Timeout
rtems:aiExample (base) hactar:~ junkes$ pvget my:custom:pv
Timeout
Does anyone have any idea what I'm overlooking?
Are you able to ping the IOC (141.14.128.12) from this host (141.14.128.70)?
Can you connect to TCP 5076?  eg. with:
telnet 141.14.128.12 5075
Also, you might setup a PVA link on this IOC with a distinctive PV name, then use 'pvxvct' on the host to look for those search broadcasts.
Re: pvxs Access/list problem Heinz Junkes via Tech-talk
pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Prev: Re: areaDetector fft of subsection of image Mark Rivers via Tech-talk
Next: caget: Identical process variable names on multiple servers J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Next: Re: pvxs Access/list problem Heinz Junkes via Tech-talk
