1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: pvxs Access/list problem
From: Heinz Junkes via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 10 Nov 2025 21:07:43 +0100
HI,
> On 10. Nov 2025, at 17:17, Michael Davidsaver <[email protected]> wrote:
> On 11/10/25 1:34 AM, Heinz Junkes (FHI) via Tech-talk wrote:
>> Unfortunately, reading the PVs doesn't work either:
>> (base) hactar:~ junkes$ env |grep EPICS_PVA
>> EPICS_PVA_ADDR_LIST1.14.128.12
>> EPICS_PVA_AUTO_ADDR_LIST=NO
>> (base) hactar:~ junkes$ pvget rtems:aiExample
>> Timeout
>> rtems:aiExample (base) hactar:~ junkes$ pvget my:custom:pv
>> Timeout
>> Does anyone have any idea what I'm overlooking?
> Are you able to ping the IOC (141.14.128.12) from this host (141.14.128.70)?
(base) hactar:~ junkes$ ifconfig en0
en0: flags�63<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	optionsPb<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
	ether 38:f9:d3:09:e8:15
	inet6 fe80::14bb:5995:e241:143e%en0 prefixlen 64 secured scopeid 0x4
	inet 141.14.128.70 netmask 0xfffff000 broadcast 141.14.143.255
	nd6 options 1<PERFORMNUD,DAD>
	media: autoselect (1000baseT <full-duplex,flow-control>)
	status: active
(base) hactar:~ junkes$ ping gonzo
PING gonzo.rz-berlin.mpg.de (141.14.128.12): 56 data bytes
64 bytes from 141.14.128.12: icmp_seq=0 ttld time=0.264 ms
64 bytes from 141.14.128.12: icmp_seq=1 ttld time=0.295 ms
64 bytes from 141.14.128.12: icmp_seq=2 ttld time=0.404 ms
^C
--- gonzo.rz-berlin.mpg.de ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.264/0.321/0.404/0.060 ms
> Can you connect to TCP 5076?  eg. with:
>> telnet 141.14.128.12 5075
(base) hactar:~ junkes$ telnet 141.14.128.12 5075
Trying 141.14.128.12...
Connected to 141.14.128.12.
Escape character is '^]'.
����	anonymousca
> Also, you might setup a PVA link on this IOC with a distinctive PV name, then use 'pvxvct' on the host to look for those search broadcasts.
rrtems@rtems-dev:~/MVME6100_7/EPICS/epics-support/pvxs/bin/linux-x86_64$ ./pvxget my:custom:pv
Timeout with 1 outstanding
leads to :
rtems@rtems-dev:~/MVME6100_7/EPICS/epics-support/pvxs/bin/linux-x86_64$ ./pvxvct -P my:custom:pv
2025-11-10T21:05:52.932458937 INFO pvxvct 141.14.131.228:39384 Beacon 0x0d5dc20423f82d6367a9991d 141.14.131.228:42479
2025-11-10T21:05:56.103177244 INFO pvxvct 141.14.128.65:36209 Searching for:
2025-11-10T21:05:56.103207467 INFO pvxvct   "my:custom:pv"
2025-11-10T21:05:56.103213055 INFO pvxvct 10.1.2.3:36209 Searching for:
2025-11-10T21:05:56.103215518 INFO pvxvct   "my:custom:pv"
2025-11-10T21:05:56.291459974 INFO pvxvct 141.14.128.65:36209 Searching for:
2025-11-10T21:05:56.291488184 INFO pvxvct   "my:custom:pv"
2025-11-10T21:05:56.291494840 INFO pvxvct 10.1.2.3:36209 Searching for:
2025-11-10T21:05:56.291505468 INFO pvxvct   "my:custom:pv"
2025-11-10T21:06:03.523642481 INFO pvxvct 141.14.136.101:44036 Beacon 0x412ce9bbb99971c4925b7f98 141.14.136.101:5075
2025-11-10T21:06:04.212423500 INFO pvxvct 141.14.135.248:60008 Beacon 0x3d28c96800000000332cf600 141.14.135.248:5075
^C2025-11-10T21:06:05.395957864 INFO pvxvct Done
Danke, Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Re: pvxs Access/list problem Michael Davidsaver via Tech-talk
Prev: Re: caget: Identical process variable names on multiple servers Paul Sichta via Tech-talk
Next: Re: caget: Identical process variable names on multiple servers J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: pvxs Access/list problem Michael Davidsaver via Tech-talk
Next: Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
